It's very nice sounding, I'd prefer deep editing for some of the delay types but the stock sounds are nice and I only use delay for solos really
eg for tape you can choose distortion on or off but not the amount, and there's no warble or crease
I basically needed to switch between reverse and crotchet via midi in a small form factor. The midi behaviour is highly customisable actually so in that respect it is very versatile
https://www.boss.info/uk/support/by_product/dd-200/owners_manuals/b8ece50c-638a-41d3-934e-b4be29bb038b/
I got a discount from Gak with the Roland midi trs cable and the unit together so it's worth hitting them up on live chat
It was the cable that was the problem to start with. I didn’t realise there’s different midi to trs cables. Type A,B,C. I ended up cutting the cable and re-soldering it so the tip and ring on the trs went to the correct midi pin. It worked fine afterwards.
i love the size of the dd200 too. I thought the dd500, timeline were too big for my needs.
How I sorted it was looking at the midi table for the g2 and I noticed that the program change number was the same as the foot switch number on the g2. So bank 1 went from 1- 14 band 2 from 15-24.
mark.
