Running with a Klone, Thorpy Warthog, Thorpy Team Medic before and a Boss RV-5 after into a Tone King Falcon. Also played it through my Mesa Maverick.
Dislikes:
1. Only four preset slots. I wish you could dial in and save your preference for each delay type like you can on the EHX Grand Canyon.
2. The time control is overly complicated with two settings and two ways to change the time. I'm getting used to it but it's a learning curve. You can dial in exactly the BPM or MS from this control.
3. Nothing else.
1. There are endless opportunities for creating almost any type of delay easily and quickly.
2. The tone of the pedal is truly exceptional. I think this may be the only reverb / delay / modulation pedal I have used that appears to improve your core tone.
3. The Mod Depth and Param controls are really well thought out and work beautifully. For example, on Standard delay setting Param controls the the attack of the delay and makes a significant difference to how clean and digital it sounds depending on where you set the Param.
4. Design, size and ease of use. It's slightly bigger than an old DOD pedal in footprint. The footswitches are angled well.
5. The looper is great. Dead easy to use and sounds as good as the rest of the pedal.
6. Ambient options are fantastic. Reverse mode with the right setting produces a gorgeous swell and sparkle. Tera Echo and Pad are just made for ambient textures which you can loop and play over.
7. Totally silent operation. I can only think that the buffer also helps with the tone.
8. 'Tis all for now.
Have barely scratched the surface but I likes what I sees so far.
The Team Medic keeps everything in check for sure but the DD 200 certainly seems to improve the quality of the tone.
I picked up my first Tera Echo off Gumtree a few years ago for £75 in mint condition. I can't find one now for much under £100. Used DD-7 around £75?
If you said £170 for a DD-7 & TE-2 used, another £50 for a new DD-200 seemed an easy decision.
