Both also have a slight problem with bleed from the overdrive sound into the bypass, if they're not run after another buffered pedal - the SD-1 usually worse, although it varies from one example to another.
I am a fan of the Boss buffered switching, but this is a definite problem with this particular pedal - although it's apparently been fixed on the expensive Waza Craft version (which I haven't tried yet, because I am tight-fisted...). It doesn't apply to any other Boss pedal as far as I know, other than the OD-1.
But why would you want to use an *overdrive* pedal like that? It’s an overdrive, not a clean boost!
(Just kidding, I know a lot of people do...)
