Skippys Refinish Isolation Projects (Tele, Jag, Strat) and AMPs
  • skippy76skippy76 Frets: 618
    Cheers @greggreg66 ;
    Clear coats are now on, waiting for them to go nice  and hard before I start the lacquer checking process
    Updating with Isolation Project 2:
    Petes old Fender Road Worn Tele will be getting a refin.
    I was waiting to see what the grain was like before I decided between a 3 tone burst or a solid colour, the grain is ok so could go either way.
    I have these colours at home already: 3 Tone early 60s burst, Shell Pink, Shorline Gold, Fiesta Red or Surf Green
    I’m thinking Aged Surf Green with a black guard and rosewood neck....
  • munckeemunckee Frets: 12458
    Shell pink!!
    I'm considering a refin of a decent guitar so rather than my usual sand spray over existing finish then clear - if I strip back to wood I thought I needed to undercoat, then colour, then clear - but you haven't undercoated the jm obviously - so did you use sanding sealer - colours - clear coat?
    What stages did you sand?
    Thanks in advance
    edited April 2020
    No worries @munckee ;;
    The grain on the alder Jag body is tight so I didn’t use a coat of sealer, instead I tested an area directly with the clear amber, it sealed it well and didn’t get ‘absorbed” so all good.
    i then used the tobacco brown on the edges and eased in the burst, once I had it pretty even I then blended with a coat of clear cherry.
    i let it dry and the next day gave it light rubdown with 600/800 grit wet and dry (it was pretty flat already).
    Three coats of clear followed, they were rubbed down with 600/800/1200 then I gave it a light going over with Tcut, leaves it wit a semi gloss finish.
    Hope that helps
    edited April 2020
    Couple of progress pics, still needs more clears, flatting, polishing, ageing and assembling!
    I’m not too worried about the odd imperfection where the body had been previously road worn, ill use these as a starting point for the ageing process, using the old less is more approach
  • SteveRobinsonSteveRobinson Frets: 7091
    Nice! I like the parchment guard best I think
    I like anything but the black. Got a tort  guard?  Looking good though.
    Cheers boys, I like the bottom one (mint) or tort is a good call.
    I’ll need buy one!
  • hoopshoops Frets: 227
    Looking great. Mint green guard I reckon.
    Progress shots and a side by side with a Fender Custom Shop Surf Green 1960
    Not going too heavy of the wear just yet, just some dinks and scrapes in the exposed edge areas
    I like the level of wear on your Tele better. I like old looking guitars rather than not been looked after guitars.
    Cheers mate, when the lacquer checking is done its going to look pretty cool imo
    Excellent work. Love it!
    Project #3!
    Shoreline Gold over Three Tone Sunburst
    Ive tried the stencil approach on this one to make sure I get down to the burst layer “accurately”, need some work work to “organically” shape some of the chips and also get down to the wood in places.
    Lacquer checking next after the nitro has hardened up.
    Quick update, pretty much done. I realise this won't be everyone's cup of tea but I wanted to try something slightly different.
    I used a CS Mike Landau Strat as a reference for the ageing on this one
    <blockquote class="imgur-embed-pub" lang="en" data-id="iRHFWYF"><a href="https://imgur.com/iRHFWYF">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
    Looks fantastic even with the wrong fretboard for shoreline gold : )
    Thanks mate! I didn't have a maple neck unfortunately :(
    I am on the look out for a MIM 50s one though to keep it all Fender MIM.
  • PeteCPeteC Frets: 409
    Knockout - love that Tele !
    They both look excellent together.
