Fender Princeton Custom Solid Timber Cabs and baffles
Hi all,
Ive cleaned this thread up, just selling hand made Princeton Cabs here now (you can PM me if you’re after something different).
Cab 1 - Aged/“antique” finish solid pineIf you have a Princeton 65 or 68 Reissue then your chassis will drop straight in but removing the 4 bolts in the top ”straps”, side the chassis out and into the new cab, replace straps and 4 bolts.
Depending on what look you are going for you can bolt your baffle (with speaker attached) straight in with four/six screws.
Alternatively if you wanted a birch ply baffle in 10” or 12” I have a couple left over from my build.
Price for the cab ready to take the chassis and baffle is £100 (pm if you would like a new baffle as well)
SOLD two stock original Fender cabs, the 65 Cab is in excellent condition £35 and the 68 is in great condition with three small holes where the tilt legs were located £30
Cheers
Toby
1. Is that a posted price?
2. Whats the weight like compared to the stock cab?
soundcloud.com/thecolourbox-1
PM’s replied to.
The internal dims for the chassis are 471mm x 204mm, the stock cabs allow for tolerance and have a gap of a few mms either side, mine are the same.
And the mounting holes are set using my PRRI 65 so will be a direct swap for other PRRIs.
Postage will be around £15 UPS next day.
I haven’t weighed them but they are lighter than the stock tolex’d cabs.
Hope that helps
Stock cabs SPF
Pine Cab still available.
Cheers
Price drop to £100 for the pine cab for the weekend.
Cheers
Hand built solid Poplar cabinet
12” Princeton Birch Ply Baffle - £50
Straight swap for the stock baffle and takes a 12 inch speaker. I have one in oxblood and one in wheat.
Obviously with a speaker mounted you wont see the 12” circle of back lit grill cloth!
The materials cost me around £30 so the other £20 just covers a bit of my build time, but I’m mainly doing these projects to stay busy while furloughed. They are not perfect but are are very good option for the price.
If you’re looking for some real life feedback @JerkMoans has one of my pine cabs and baffles
I now have a new Princeton Stock black tolex cab up for grabs, £50
Also the pine and poplar cabs are still available
cheers
Toby
