The Fretboard Rickenbacker Club (NSFW)
  • ICBMICBM Frets: 72890
    I'm not sure why there is so much variation either, but you'd be doing very well to get a 360 for as low as a grand now. Some colours are definitely more desirable than others though.
  • GavRichListGavRichList Frets: 7233
    id imagine a FG 360/6 in good nick with the case should fall around the 1500 mark, give or take £100 or so each way depending on how good a day you're having. Buying from a shop will inflate that, but truth be told, you can have a new one for under £2k if you put the legwork in, so dont over-pay.
  • andy1839andy1839 Frets: 2199
    Thanks both, I appreciate your input.
    It might be nice just to try one out and see what they're like.
    I've almost pulled the trigger on a new 620/660 a few times when I saw them in the sales but always either talked myself out of it or procrastinated too long and they sold.
    I shall see what today brings...
  • oh_pollooh_pollo Frets: 873
    Thomann have the 330 for £1700 which is the cheapest I've seen new. https://www.thomann.de/gb/rickenbacker_330mg.htm
    yeah, DV247 and Thomann are by far and away the cheapest, but I'd only consider those in stock as I spoke with both of them, and they've said that they're having to wait up to 2 years for some orders from Rickenbacker.
  • DarnWeightDarnWeight Frets: 2566
    Yeah, more or less this.  If it helps, I got my JG 360/6 (pretty much mint, used/demo guitar) for about £1300.  That was 3 years ago now, but I'd expect a decent used example to be in roughly the same ballpark.  Maybe £1200-1500?...Probably on the higher end of that for FG.
    New fangled trading feedback link right here!
    @GavRichList got a couple of photos now.
    looks legit! selector switch-tip has been swapped, and it looks to have 2 bridges...but otherwise, definitely real
    Nice one!
    Do they use the same case for 330 & 360?
    Would there any reason for two bridges? Do they fail often?
  • TeyeplayerTeyeplayer Frets: 3322
    Looks lovely @andy1839, are you going to pull the trigger on this one (I would)?
    same case, yes. I believe the bridges *can* rattle a bit...but that said, both of mine are solid - I think it may be a case like so many things, of exaggerated on the ol' internet.
    The whole switch has been swapped - that looks like a Schaller type, not a Switchcraft.
    It's worth putting the right one in, they're just better. Rickysounds have them - they're not the standard ones you can get elsewhere, they have a 'long bat' toggle. Not cheap unfortunately!
    Ah, ok.
    It does have the stereo thingy on it too.
    The stereo thing is really cool - I've used it in an 'acoustic' duo context, with a singer who doesn't play guitar so there's only one instrument. If you DI the neck pickup with some EQ - straight into the PA, not through an amp simulator - and run the bridge pickup into an electric guitar amp (or amp simulator into the PA) with an overdriven sound and a bit of reverb, when you play strummed/picked parts you get what sounds like two guitars, a more 'acoustic' rhythm part with an 'electric' lead at the same time.
    So much so that when I fixed up my old 450 - which is normally a mono model, but someone had drilled a new jack socket hole in the side when they'd tried to turn it into something more like a Les Paul (!) - I added the second jack and the stereo wiring.
    It doesn't make any difference to the switch though, it's the same for both types of wiring - it's just the jacks that are different.
  • NervousJohnNervousJohn Frets: 191
    They do rattle, and come loose. In fact one of my bridge screws fell out once, so I’ve used a dab of superglue to hold them in.
  • eoinzyeoinzy Frets: 128
    edited July 2022
  • RonnieHotdogsRonnieHotdogs Frets: 187
    edited June 2020
    My '99 360JG/6 and 89 340MG/6 - sorry for big photos
    20170408-213532
    20170408-213403
    20180531-200947
    20170531-174155
    20190901-195823
    20180614-144820
    20180614-173926
    0reaction image LOL 5reaction image Wow! 1reaction image Wisdom
  • prowlaprowla Frets: 4978
    Kahler, Seymour Duncan, Freeway (6-position) selector switch.
    edited June 2020
