It might be nice just to try one out and see what they're like.
I've almost pulled the trigger on a new 620/660 a few times when I saw them in the sales but always either talked myself out of it or procrastinated too long and they sold.
I shall see what today brings...
Do they use the same case for 330 & 360?
Would there any reason for two bridges? Do they fail often?
It's worth putting the right one in, they're just better. Rickysounds have them - they're not the standard ones you can get elsewhere, they have a 'long bat' toggle. Not cheap unfortunately!
It does have the stereo thingy on it too.
So much so that when I fixed up my old 450 - which is normally a mono model, but someone had drilled a new jack socket hole in the side when they'd tried to turn it into something more like a Les Paul (!) - I added the second jack and the stereo wiring.
It doesn't make any difference to the switch though, it's the same for both types of wiring - it's just the jacks that are different.
