https://www.jedspeds.co.uk/product-page/multi-meter
This one from Toolstation caught my eye, a bit more but their stuff usually lasts.
https://www.toolstation.com/tis-258-digital-multimeter-with-temperature-probe/p87874?store=AI&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gclid=CjwKCAjw_-D3BRBIEiwAjVMy7MzI7AOSVWc2kQLWWpIVRF4KIJKTuRDoKeiU-Nzr5djioyEk9dsPsRoCCmYQAvD_BwE#full-desc
@rsvmark my experience is when the diodes are cooked they don't pass anything in either direction. Are they in place? If they wired in opposite directions as clipping diodes then there will be a route in either direction through one diode or the other from the same contact points
yes they are in place. I triple checked the orientation and how to use the multi meter! I managed to solder them in place neatly and I am generally I am tracing the circuit/component and checking for shorts if I can. So armed with the warning from fuzzdog, I was keen to check the diodes were still working. So using the multimeter I checked again and I get a voltage drop both ways.... And lo and behold I do....so it looks like I haven’t fecked it up after all! Great news!
My LED wiring is a bit untidy but the rest is fairly neat. I'm just glad it works
Check out this guy's work, unbelievable https://reeveselectro.co.uk/product/2n2face-silicon-fuzzface
https://live.staticflickr.com/65535/50076738952_d4a3a05661_k.jpg ;
Everything built on the board, pots and switch positioned and soldered. So far so good. Checked the circuits and all pots operational, no crackles, and the switch works fine. Yippee....... BUT the volume dramatically drops off using the switch. When the switch is in up or centre mode, its nice and fine and no probs. When it is in the lower position there is a big drop off which i am sure isnt part of the plan! @andy1839 did yours do this? Any suggestions before contacting fuzzdog.
Thanks.
Mines quite trebly too, needs careful adjusting of the air and eq to tame it. I've been running the treble almost off and the Air higher.
The foxxton woods is a total beast. Tried it in rehearsal the other night, I think it can replace both my fuzz and my octave fuzz pedals. Heavier than I expected (half fuzz half metal zone lol) but worked really well in the room
