Caution - dont buy modded guitars
  • blueskunkblueskunk Frets: 2890
    Nice now :)
  • WezVWezV Frets: 16734
    At the end of the day its hidden and doesn't affect functionality, other than needing some shims under the pickups.  the seller should have been a bit more honest, most would have avoided if they had seen the pic and the seller knew this.
    have a look at this ebay listing, scroll through the pics in the actual listing
    Doesn't stop me lusting after it. although i would rather have this one I expect it looks the same under the hood
  • LoobsLoobs Frets: 3832
    Ouch. That was a bit crafty.
    Cool guitar, though.
  • 57Deluxe57Deluxe Frets: 7342
    ...is prob why he sold it too... bugged the shit outta him!
    <Vintage BOSS Upgrades>
    ICBM said:
    Seriously, how could you imagine that a Jag that's been fitted with humbuckers would be 'reversible'? (Assuming they weren't single-coil-sized, like Duncan Rails or JB Jr etc.)
    Even assuming the neatest possible job of fitting them, it's never going to be reversible, because it can't be done in the first place without routing.
    And if something can't be done without routing, you have to assume that sort of workmanship - or worse - until proven otherwise...
    ... and there really is worse! If you don't believe someone could do such a hamfisted job on a £1500 guitar, you probably haven't seen some of the horrors professional repairers get asked to put right :).
    maybe my choice of wording is a little off by using the word reversible.
    If you look at this picture, a jag pickup should still be able to be fitted into the bridge position as the width of the routing is still intact
    I was hoping for something similar.
    and if we are getting technical I did manage to reverse the buckers with the help of some pine :-P
  • EdGripEdGrip Frets: 736
    Sounds like you got a great guitar at a bargain price. :)
  • strtdvstrtdv Frets: 2440
    meltedbuzzbox;293530" said:
    @strtdv Jag pickups are actually mounted straight to the body that is why I had to fill in the craters with wood. ;-)
    Ah, didn't realise this. I'm sure it still make minimal difference to the tone. To be fair though an AVRI would need to have some very poor mods to not be worth £500, it's still a good deal.
    Seems to be that if it seems too good to be true, it usually is. I bought a partscaster on the old harmony central forums that was very cheap (under £200 with a MIM classic player neck, 2 piece ash might mite body, and humbucker bridge/P90 neck). When it arrived there were a few marks on the body that the seller hadn't mentioned, and the pickups were wired incorrectly. I fixed it up, but didn't bond with it, sold it for a profit.
  • GagarynGagaryn Frets: 1553
    It was reversible - 10 minutes with a chisel and a dremel, and some off cuts of wood and the single coils can be refitted. Scratchplate back on and the repair is invisible. And you have a cracking guitar for a budget price.
  • FX_MunkeeFX_Munkee Frets: 2478
    <shrugs> I always assumed that's why god invented scratchplates, to hide the unholy mess that I made of the routing.
    Anyway, Dremels, they're brilliant aren't they?
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
  • ''and assured me it was reversible''
    well you did reverse it . lol
  • gusman2xgusman2x Frets: 921
    Yeah, wouldn't really have expected much different to be honest. How did the seller respond when you took it up with him?
  • ICBMICBM Frets: 72474
    Invisible (from the outside!) and reversible aren't the same thing :).
    It may well be a great guitar now, but it can never be put back to how it was originally no matter what you do and hence is not reversible.
    That may not matter to some people, but it was dishonest to describe it as such.
    edited July 2014
    At least they didn't do a Fender "swimming pool" route.
    This is how USA made strats (excluding reissues) came pre-1998:
    Even now, the majority come with a "universal" HSH route rather than an SSS route
    Jesus, they even made that one the wrong way round...
  • I'd love a swimming pool route strat.
    http://media-cache-ak0.pinimg.com/originals/9b/30/a8/9b30a8984c865f0f7d69343d91638e36.jpg
  • ThePrettyDamnedThePrettyDamned Frets: 7488
    edited July 2014
    ICBM;294194" said:
    [quote=ThePrettyDamned]
    http://media-cache-ak0.pinimg.com/originals/9b/30/a8/9b30a8984c865f0f7d69343d91638e36.jpg[/quote]
    Sorry, yeah it was a typo.
    I want a strat route swimming pool. :) :p
    I haven't took it up with him, being in the US and all the rest of the shenanigans involved its a bit of a lost cause.
    However if you are on OSG and someone called gutterrock is selling a Jag you know what questions to ask ;-)
    Original (on the inside!) and reversible aren't the same thing. ;-)
    The seller claimed it was reversible - i.e. that single coils could be refitted instead of the replacement humbuckers. And they have - so it was. :-)
    No claims of originality or 'mintytude' were made as far as I know. In the same way as it was obvious that the scratchplate had bigger holes in it than it used to, it was obvious that the body would be affected too. Granted, it wasn't the neatest job but it doesn't really matter as it's hidden.
  • JD50JD50 Frets: 660
    I wonder how many router bits were used, given the scorch marks the first bit must have blunt on first pass....... That's if they knew what they were supposed to be doing, clearly they didn't. Looks like they guessed the depth locked up and plunged to the bottom.
    Easy enough to square up and drop a couple blocks in if you want to do it properly. Either way a great guitar for the money you paid regardless of the routes.
