It's hard to say really.
I tried to do a direct A/B but the patches set up with the Power Stage sound too squishy through the Marshall and the patches set up with the Marshall sounded too hard with the Power Stage so you can switch amp and patch, but then you are maybe just testing which patch you did a better job with.
When I was gigging a modeler I used the FX return of a Jet City head because they are small, light, cheap, easy to repair and seem to work pretty well.
The biggest difference for me has been that EL84 amps seem to lack low end grunt compared to EL34 or 6L6 amps which I usually prefer. Now that could be because they usually have big transformers and higher wattages so you can draw your own conclusions.
Honestly the SD doeznt lack compared to any of them and the weight save is usefull.
I have thoughts.
It was plenty loud enough. But it didn't "feel" right to me. I switched over to my JVM half way through the day, and was much happier with it than the QC+PS combo.
Hmmmmmm.
Just wasn't rock n roll enough for me I suppose.
Is it the 5150 clone??
The Amplifire and IRT-X is by far the most flexible. Most of the time I use it like a 3 channel amp with boost and inbuilt effects. It is really convenient for use out of the house as my mate has a PA that I can plug straight into. The models are probably at about 90% of the sound of a good amp. It's great for recording (no micing etc) and for silent practive with headphones (although I generally try to avoid that). I prefer to use it with an FRFR as that gives me more cab options and makes it possible to switch from e.g. Fender clean to dirty Marshall.
I really don't need any more gear!
@WiresDreamDisasters the Mesa is the earlier EL84 version so a little different from the later 6L6 one.
@IBCM - if I rewired my cab from 16-ohms to 4-ohms, would that be more efficient for the Powerstage 200?? Would I get more level out of it, and would it improve the feel/tone ???
