Fan fret guitars
CHRISB50CHRISB50 Frets: 4366
Anyone play / played one? What are they like (I'm imagining like a standard guitar but with strangely spaced frets) to play? Do they actually work?
I've read that it was designed originally for bending. Then I've also read that it retains a more even tension between all the strings, therefore improving tone etc.
I've got no interest in getting one. I'm just interested to hear from people that have used them.
Anyone?
  • octatonicoctatonic Frets: 33904
    Anyone?
    Not exactly.
    The main reason for a fan fret is for string tension to be maintained for extended range instruments.
    The problem that exists is with a 25.5" scale 8 string is the bass strings are flabby due to lower string tension and the intonation is pretty poor on these string too.
    Fan frets allow you to have better intonation on all the strings due to having different scale length on these string.
    IMHO there isn't much point using fan fret on a 6 string instrument unless you wish to use a vastly different tuning to standard.
  • Yup, that.
    I have never used one, but having played a 7 and 8 string (fender scale) it was obvious they needed more tension. The 7 string could cope with a heavier string, but the 8 could probably benefit.
    I've actually written to a forum builder to see if he can wood work me one at some point in the future so I can finish it and wire it up.
    I think they look stunning, too. I'd almost consider it a different instrument - a true solo instrument, like a piano. Plenty of melodic stuff out there with open tunings that have a nice, big bass sound and a clear melody.
  • GuyBodenGuyBoden Frets: 766
    edited July 2014
    I've always been intrigued in fanned frets, it must be a complex design calculation due to the varying tensions that are created when fretting different notes, when we fret a note we are constantly changing the scale length of the string.  A nice and tight open "E" could have an overtight 12th fret note.
    But, the fanned fret guitar should be more "in tune" than a standard guitar.
  • EvilmagsEvilmags Frets: 5158
    They are easy to adjust to and if you drop below D it sounds more balanced across the strings.
    edited July 2014
    No, tension is a constant.
    The calculation isn't that complex actually- I've done calculations of 16th Century Chitarrone that are more complex.
  • fretmeisterfretmeister Frets: 24784
    I had a Dingwall ABZ5 fan fret bass.
    It was very good indeed and the 37 inch low B was amazing - very piano like. It was easy to play and I think it took less than 5 mins to get used to it. For some chord shapes it was actually easier because I didn't have to fight to get my fingers in a straight line.
    The only reason I sold it was because it was a sod getting strings I liked. Even the D'addario Super Long scale strings were a few mm short on the B.
    Dingwall now do a 32 to 35inch 5 string Super-Jazz and I'm very keen to try it!
  • WezVWezV Frets: 16916
    edited July 2014
    piano like is exactly the term i use for this.
    I totally disagree that the benefits are only there on extended range instruments.  Parallel frets are a compromise, but they are a compromise most of us are totally fine with.  I would never say fanned frets are essential on a 6  string, but its daft to say the benefit of fanned frets is only seen on 7 or 8 strings, those benefits help over the 6 normal strings too.  We just happen to be more used to the compromise on standard guitars
    So far I have made 3 and am currently on the 4th and 5th.  All have been 6 strings, one will be a 9 string but strung double course on the high strings, one has been a baritone 6.
    they are more confusing to look at than they are to play.   Most people have absolutely no issue adjusting and are mostly there within 30 seconds
    my first one was done with  a very slight fan of 25" treble to 26" bass - fanning out from the 6th fret.  Its beautiful in standard tuning with a set of 9's or 10's.  It also works well with a heavy bottom set and some downtuning, better than a parallel fret guitar does.  nobody has ever struggled to adapt to this guitar.
    a few years ago I handed one to my cousin so we could do some vids.  This one is 25 - 26.5" and he only had a few minutes with it before we started recording - there are a couple of vids of the same guitar
    Thanks, I learn something new everyday.
    Nice. I've wondered what a Gibson high string, fender low string 6 string guitar would be like. Super duper easy legato up high, but decent chugging elsewhere.
  • CHRISB50CHRISB50 Frets: 4366
    Cheers people.
    I want to try one now!
  • dean2371dean2371 Frets: 139
    How do you work out the fret distances? Are there tables or formulae to do the calculations?
  • TTonyTTony Frets: 27862
    That's actually *MY* beauty.
    @WezV built it for me a few years ago.  I wanted something "different" but was also a little worried about how playable it would be - never having played a fanned fret guitar!
    So ...
    It feels surprisingly natural and not strange at all.  I can pick it up having played "normal" guitars for months, and fingers just fall into place with no real thought or adjustment.  The spec is also very flexible (P90, tapped HB and piezo) and the workmanship is not too shoddy either.  I probably play it more because of the tonal options and the quality of the guitar than because it's a fanned fret - which I guess means that the FF aspect is no big deal.
    you use one scale for the treble side and another for the bass side, decide which fret is goign to be perpendicular to the centre line then you join the dots
    that's the basic principal anyway.  there are a few things to consider.  Obviously if you wanted the high e bang on 25" scale you wouldn't measure 25" scale on the treble edge of the fretboard, you would measure it directly on the  proposed string path because the edge will be slightly shorter
    the perpendicualr fret position will affect the feel.  going somewhere between fret 3-7 keeps it feeling quite normal at the nut but quite angled up the top end, which actual helps reach those frets easier.   12th fret gives a nice balance.  I have seen one made with a normal straight bridge which meant the nut was very angled  and first position chords were severly compromised
    Intriguing. I'm just about to start building a neck so will give this some serious thought. May be a bit ambitious though as it's only the third neck I've built.
    I guess you wouldn't be able to find a fretting template / guide for it, but as long as your measuring and cutting is accurate, would it be any more difficult than cutting the slots for a standard frets?
    Very true. I feel a bit of calculating and measuring coming on
    slotting the fretboard is the bit i find least confusing, although carefully marking and hand slotting all the slots does take a long time.  I have a couple of maple boards slotted by @GSPbasses and i fully intend on getting some done in ebony soon.  I have done them the slow way by hand a few times and its enough to convince me that its worth paying someone else to do that particular task
    however, drawing and working it all out yourself will answer a hell of a lot of questions you will have as you start to build.
    There is a decision what to do behind the nut
    look behind the nut on this:
    compared to this:
    the first one is made with a normal angled headstock which leave a triangle of spare wood on the treble side and you need to make sure the strings won't foul that section.
    the bottom one is done with a compound headstock angle  so it angles back evenly from the nut.... which i still struggle to get me head around
    I was wondering about the nut end. I've found a couple of guide calculators via Google which are interesting. I don't mind doing it myself; I find it strangely therapeutic. I've got leave from work coming up and its either do an enjoyable guitar related project or get saddled with a list of DIY jobs to do; I know which one I'd prefer!
  • JayGeeJayGee Frets: 1284
    compared to this:
    Would a zero fret and a conventional (perpendicular) nut (which is what I initially assumed was going on with the top picture until I actually read thevwhole post and then zoomed in and looked a bit more closely...) be considered a complete cop-out...?
    Not a bad idea actually, although i do wonder whether having the nut further away from the zero fret could reduce its effectiveness.
    Although i am currently doing my first with a proper compound headstock angle and its going really well. Easier to do than describe.
