Advice re pick/plectrums please.
  • I've also settled on the Dunlop tortex 0.73mm's. A happy medium between strumming and single note playing, it sits right for me.
  • As well as the regular Dunlop Tortex  mentioned above, Dunlop do a range of "Gel" picks which are good. The green med/light is probably a touch thicker than your current pick.
    https://www.jimdunlop.com/gels-green-medium-light-pick/
    Thanks.
    Looks interesting. Thanks.
  • KeefyKeefy Frets: 2331
    Another vote for Dunlop Tortex 0.73mm (yellow) - I like the texture, which is moderately grippy.
    Popular choice.
  • MellishMellish Frets: 947
    A favourite pick with many years ago was a felt plectrum. It had its own distinctive sound described by many back then as "mellow". However, they are quite thick, and I mention them because the OP mentioned mellow :)
    Thank you. Don’t think I’ve ever seen one.
    They're still made and Google search will bring them up :)
    Just be a bit careful, I have some felt picks for ukulele, and I tried one on my acoustic guitar - it sounded quite nice and mellow, but shredded the pick. So just check whether any you get are intended for steel strings, as there may be different kinds.
    Good point @Mattharrier. That could well be the case :)
  • rogdrogd Frets: 1532
    I seem to remember that felt picks were meant for bass guitars.
    Not sure @rogd.i know some acoustic guitarists used them way back when. I would guess that they wear faster but I could be wrong :)
  • sev112sev112 Frets: 2814
    In addition to my post earlier about using Dunlop picks of various colour / thicknesss, the ones I use are the triangle ones, which mean they are flat
    which allows me to do something I’ve not seen other do / talk about,
    and that is to use 2 at the same time , when strumming a steel string acoustic.
    It is surprisingly easy (I cam across it by accident) and it gives a more jangly , thicker sound because you have 2 tips (or a tip and a bit of side) occurring at the same time
    you can get some nice sounds doing the same with electric and reverb / delay / chorus as well
    flat picking isn’t as easy tho
    @jimkehoe. Be aware that felt picks are much thicker, feel a bit odd. I'd buy a single rather than send off for a pack :)
    I think I’ll explore other possibilities first but certainly not discounting the possibility.
    @sev112. Do you mean Dunlop Ultex? They're triangles. I find they're easier to hold because of the larger surface area :)
    @mellish, yes triangle but Tortx, as they are coloured for thickness. I have some ultex ones but they are the same colour so can’t quickly pick up the one I want
    @sev112. That's the beauty of the Tortex, the colour tells you. I favour the red and the orange, but that's just because I can't get used to 1mm or up. I like to feel a bit of give (flex) :)
