John Cruz Custom Guitars(Update from John Cruz)
  • skippy76skippy76 Frets: 619
    Selling out the very first batch could be down to "investors" getting in on the ground floor.
    Be interesting to see if they keep selling over time.
    Not a fan of the blokes views for what its worth
  • TeleMasterTeleMaster Frets: 10375
    Boromedic said:
    Boromedic said:
    In fairness Suhr and Anderson are an improvement on the originals, a standard Suhr or Anderson is very much a better guitar out of the box than a standard Fender as it's had more care and attention afforded to it during manufacture. I would also argue that they use better materials in the build than a standard Fender.
    Objectively you could argue that but as soon as you put two guitars in your hands you may well like the Fender more. It’s not like they’re cheap, or shabby instruments and Custom Shop guitars are excellent instruments with particular neck carves that you just might like more.
    I said standard Fender, not custom shop.... I have a CS Strat, it's tactile and very lovely, it's very high quality. The Anderson I have and the Suhr I've played are head and shoulders above any Standard Fender out of the box. You could make a better guitar out of the standard but you can roll a turd in glitter it's still a turd. The little refinements that TA and Suhr make go a long way.
    Yes I know you said Fender. I also said Fender, as in any Fender. I was then talking about the excellence of the Custom Shop in general as an aside, because you would have to compare the top of the line Suhr to a top of the line Fender.
    The same logic applies to Mexican standards or Elites or Classic Vibes. Just because something is better on paper, it doesn’t mean it’s better when you play it.
  • crunchmancrunchman Frets: 11495
    Philly_Q said:
    It's interesting the number of times this forum manages to reduce all Fender and similar guitars to "just a neck bolted to a body" and therefore worth a few hundred quid at most.
    It's as if all those other things like pickups, electronics, hardware, paint, fretwork and the actual construction of that neck and body are completely irrelevant.
    Oh come on! The actual cost of the parts of that guitar will be less than $500 to John Cruz. Construction of a strat body and neck is extremely simple for anyone with a modicum of woodworking skills. The fretwork and setup is a doddle for any experienced tech. The relicing isn’t rocket science either. You’re paying $1000 for the guitar and $7000 for the name on the headstock.
    He’s hardly the first to do this and won’t be the last but as long as people want to spend money on guitars like that good luck to him.
    He might be able to get some kind of trade discount, but I don't think he will be buying all the parts for $500.  At that level, he will be using boutique pickups and hardware.  I haven't checked exactly what hardware is on his guitars, but a boutique set of Strat pickups like Lindy Fralin is around $300 retail.  Even if he can get a discount, he's paying $200 just for the pickups.
    Other hardware like tuners, bridge, pots, knobs, jackplates, frets, nut blanks etc all cost money.
    Then you have to think about wood.  Top quality swamp ash body wood is £90 at David Dyke for a two piece body.  With a good quality maple neck blank, plus a fingerboard, you would be well over £100.  Again, he might get a discount compared with what we can get, but he's still probably looking at $100 dollars for the wood.
    Then he has to buy all the stuff for finishing.  Lacquer, plus consumables like sandpaper.
    There is significantly more than $500 dollars worth of parts in there.
    Then you add workshop overheads - cost of renting and maintaining a workshop, cost of buying and maintaining tools, heating, lighting, spray booth etc.
    Then other business overheads like a website and marketing, public liability insurance.
    There is a lot of work that goes into making a guitar.  I made a guitar at Crimson - actually I ran out of time, and ended up doing the wiring and some hardware at home.  I put over 60 hours into that - and it only had a flash coat finish.  You would need to add quite a lot more time to that for a gloss finish (even before relicing it).  Someone who knows what he's doing could do it a lot quicker than me, but there is still a lot of labour involved.  There is no way he can make that guitar for $1000 dollars unless his hourly rate is in single figures.
    A Feline Tabby is £2700 on their website.  That's probably a fair cost for a high quality small shop bolt on.  It allows the maker to actually feed himself.  That's still an awful lot less than $8000 so there is some truth to your point about paying for the name with John Cruz, but you did exaggerate to make your point.
  • victorludorumvictorludorum Frets: 1053
    edited March 2022
    Wasn't there a thread on these a couple of years ago where they were being blown out by some retailer for 800 USD or something? Maybe I'm thinking of John Page, but either way i remember the headstock being the problem for some on here, me included.
  • Philly_QPhilly_Q Frets: 23507
    edited March 2022
    That was probably the John Page ones, Coda had a couple.  They were made in Japan(?) and not massively expensive... not as cheap as $800 but closer to that than $8,000.
    (Edit: I see you updated as I was posting! :) )
  • joeWjoeW Frets: 469
    Mine is arriving next week. Will post a review and compare to my Ian Elson - wonder if Cruz employs rodents to gnaw his nut slots…
  • teradaterada Frets: 5114
    The perfect example of what a hand made £800 bolt on actually looks like.
  • RaymondLinRaymondLin Frets: 12020
    edited March 2022
    Take away the bigotted tweet that got him sacked, and take the guitar on its own merit.
    It's just going to be on par on when he used to work for Fender, so essentially this would be a Fender Masterbuilt price guitar and you can get them for about £6k.  So objectively, it makes this overpriced.  Unless his name is larger and worth more than Fender itself.
    Which to me is not as when you consider the name, I have to take into account of the bigotary.
  • bertiebertie Frets: 13576
    Lewy said:
    . $8000 probably corresponds quite directly with Masterbuilt CS
    is it ?  crikey,  I was thinking £5k absolute tops
  • matt_seftonmatt_sefton Frets: 833
    It’s the internet. Exaggerating to make a point shouldn’t shock you! You don’t need to lecture me on the cost of building guitars or running a business. I’ve been building guitars since 1980, went to the London College of Furniture to study it and run my own business outside of that. You’re being incredibly naïve about how much something costs to make and the associated running costs and exactly buying in to the hype that boutique guitars like this seem to generate and thrive on. John Cruz is perfectly entitled to charge whatever he likes for his partscasters but please don’t pretend they’re very much more than that. Respectfully :-)
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
  • Dan_HalenDan_Halen Frets: 1655
    Seems a bit agressive. He's quite obviously trying to illustrate a point and suggest there's maybe a bit more to it that how much a bit of wood and someone's time costs. Hardly saying 'no, they're definitely worth every penny'.
    Anyway, literally no-one thinks his guitars are 8k worth of guitar but if that's what he charges it's what he charges. It's about the ballpark for a Fender Masterbuilt so hardly a suprise. Given, by all accounts he's sold them all, I'd say he might know what he's doing.
    You run your own business - do you charge simply the sum of parts/labour for anything you produce?
  • WhitecatWhitecat Frets: 5472
  • guitars4youguitars4you Frets: 14619
    Whitecat said:
    Oooooops indeed
  • Whitecat said:
    Ach, that's grim. What an arsehole.
  • StefBStefB Frets: 2392
    Whitecat said:
    If anyone still fancies a punt after that glowing endorsement, GuitarGuitar still have a few in stock, heavily discounted to now just a couple of grand more than Fender Custom Shop equivalents - https://www.guitarguitar.co.uk/search/?Query=john+cruz
    2reaction image LOL 1reaction image Wow! 0reaction image Wisdom
    StefB said:
    With the German shop above mentioning "many with quality control issues" I think I'll pass for now... :D
  • What an a**eh**le. I feel for these people putting faith in his product.
    Whitecat said:
    edit required
  • elstoofelstoof Frets: 2562
    You've got to wonder how he became a “masterbuilder” in the first place
  • nero1701nero1701 Frets: 1510
    It's likely easier to excel when there's a large organisation behind you. Once you branch out, you soon realise there's a lot of shit behind the scenes you never knew existed.
    It's almost the DeLorean of the guitar world.
