What are the combos?
Feedback
(grainy old pic)
If it is in a public space that you want it to look nice then get a matching cab, What is the matching cab, I am sure some cab builders could do a matching cab for less than £600
BTW if you do use your combo make sure to disconnect the combo amp from the speaker, you can not run two amps into one speaker.
Only thing to bear in mind is resell value might not be high if it’s too unique to your requirements.
Ebay mark7777_1
Branded cabs are often massively overpriced for what they are. Plenty of good zillas our there and 2nd hand speakers, you can get a creamback Heavy for around £120 2nd hand, or various other good speakers and a quality empty head for around £150.
Other way is to instead save up for a combo of the same brand/colour then sit head on top then you have 2 amp sounds and better resale-ability!
It's a Hook Wizard
https://www.instagram.com/insta.guitarstuff/
you missed this a month ago!
https://www.thefretboard.co.uk/discussion/223116/sold-2-unloaded-zilla-cabs-sold#latest
When I finally got the matching 1x12 for my amp I was just happier, still chuffed with it 18 months later.
