Yep, I agree, Leon is the only one I tend to take notice of - the other so called Beta Testers (you know the ones...) are just full of their own self-importance..
I will have to give these DC's some time at some point, I think the concept of DC's in Fractal-World needs maturing a bit before the hype is relevant...what is interesting though as 1 guy over there pointed out is the new capture process for these DC's - different preamp etc etc, that could be why they are different and perhaps I don't get on with them..
@Jonathanthomas83 I'm here all day if you want to chastise me
I’ll get me coat ….
It amazes me how certain people on that forum find the time to actually play the guitar. They must be permanently sat at their computers bashing out replies, imparting their own supposed expertise whilst simultaneously crawling further up Cliffs arse
In all fairness, that guy who screenshoted his from his AF3 actually sounds OK, but as far as mic placement is concerned (or at least where the dots are) it's totally unlike where I would position a mic and in the real world would be impossible...unless its different speakers in a 412?
However, saying that, switching back to a similar IR, it still sounds better...
Oh, and I'm obviously on one of the Beta Tester's ignore list as he hasn't responded to the thread in his usual pedantic manner - I must have upset him last time around about enabling the USB port on the FM3...
I got sick of the fan noise from my Axe FX III in the otherwise silent control room so I moved it into my machine room.
This created a bit of an issue for me, which is how do I get an unbalanced cable through to the machine room without getting too much noise.
I have analogue (balanced) tie lines between the two rooms and spent a couple of hours trying different options.
The cable run from the mix position to the back of the Axe FX is about 10m.
I've connected the AFX III to my audio interface (Avid MTRX II) using AES/EBU.
Here are the various things I tried:
1. Guitar -> 10m long unbalanced cable -> Axe FX III unbalanced input
It worked but incurred a tonal penalty from the long cable plus it was impossible to have it completely avoid power cabling and therefore ended up being a bit noisy.
2. Guitar -> buffered pedal -> 10m long unbalanced cable -> Axe FX III unbalanced input
Mitigated the tonal penalty but not the noise.
3. Guitar -> API Tranzformer LX preamp pedal -> 10m XLR cable -> Radial XAMP -> Axe FX unbalanced input.
This sounded great.
The API outputs at line level, which is connected into one of the tie lines and the Radial takes it from +4dBu down to guitar level.
But I don't like having things on the floor to trip on.
4. This is what I am actually settling on.
Guitar -> any of my mic preamps with a DI (usually API 512v or 512v) -> Avid MTRX II -> Axe FX III AES/EBU input .
It has number advantages over the other set ups.
First the MTRX II's analogue to digital converters are an order of magnitude better than the Axe FX III's.
It greatly simplifies cabling, a 10ft guitar cable into a preamp HiZ input is all I need.
It is possible to switch 'Input 1' on the AFX globally to the AES/EBU input so all my patches just work, providing I get the input level right.
Latency is lower than going into the AFX's instrument input, converting to digital, back to analogue (AFX III out) and then back to digital (MTRX II in).
I did a bunch of A/B tests against the other options.
Along with option 3 this sounded best.
I do wish the AFX had BNC word clock though- everything is synced via BNC word clock.
I probably should, but I'd need to make it up.
I just don't understand why Fractal messed up so much on the Mk2 and Mk3 for the fans. Yes it can run on stage in Saudi, so what? There should be a studio edition.
Starting to wonder if I need the Mk3 now.
Here are a couple of audio files showing how close I can get.
They aren't level matched and the playing is a bit different in each take but I am pretty happy with the FM9, certainly enough to use live.
Pls excuse shitty riffing.
AFX III
FM9
Which fan did you use?
I still don't want it in the control room but it might be worth doing anyway.
https://www.amazon.co.uk/gp/product/B00KF7T9MI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Noctua NF-R8 redux-1200, Ultra Quiet Silent Fan, 3-Pin, 1200 RPM (80mm, Grey)
I fitted that in 2018I can't remember if I had to improvise the mounting or not
Also worth noting: I bought one of those cheap laser thermometers from Lidl to check the temperature of the chip in a CCTV PVR that had a whiny 1 inch fan. Turned out that fan was not needed at all, with the lid removed, it's been running fine for years now, there is a lot of over-engineering in some of these devices.
Since then, the Laser thermometer has lived in the kitchen, where it is incredibly useful for checking the temperature of pans, cooking food, and when warming up stuff in the microwave.
How do you rate the feel on the FM9?
I noticed a big step up in feel and sound from the Mk2 to the Mk3
I've never felt that feel on my Kemper, I'd say it's a step down, and the Helix I bought to go to jams is 2 steps down, hence this purchase.
So far I've ported my favourite patches, the first test for me was my old "Big sky"/Cloud type patch, which sounds great on the FM9, but I did have to lose one of the Multidelays of course.
The FM9 factory presets contain some gems, which I can't recall happening for the Mk2 or Mk3
The only thing I really miss is the second pitch block absent in the FM9.
I've never used any of the presets on the Fractal devices so can't really comment.
The first thing I do when I get a new unit is move the presets to start at preset 64 so I can use the first banks.
