Best natural, transparent, edge of break up pedal?
  • LebarqueLebarque Frets: 3953
    Regardless of pedals, are there any recorded examples of the tone you’re after?
    I like the sound of most recorded/YouTube edge-of-break-up tones, but when it comes to my set up and playing...
    Just to be the latest to add a suggestion...
    EQD Special Cranker
    Received the Special Cranker (great name) this morning and so far, so good (honeymoon period pending). Germanium mode with gain at 0 and it sounds just like my amp starting to break up. Liking.
  • GassageGassage Frets: 31071
    Kingsley Page by a country mile.
  • Lebarque said:
    Someone on here said something about Kingsley. I have been watching stuff on my brother in law’s YouTube feed which is basically classic and prog rock but I noted that Steve Rothery uses a Kingsley Jester to valve up a very clean sound. Probably too crunchy, from about 10:20, just seemed interesting in the context of this Discussion…
    https://youtu.be/5U6Dnt7LfwI?si=wsRrMLgctcAUjAVq
    I'm sure the Kingsleys are amazeballs, but I refuse to pay that much for pedals when there are so many great options around.
    The Page is less than £300 delivered, and worth every penny.
    Just don't look at the used prices for Kingsley pedals on Reverb, because they've gone silly.
  • StefBStefB Frets: 2400
    DOD Looking Glass is my stock answer when this question crops up every couple of weeks.
    Seriously, it should be made a sticky thread along with:-
    - best clean pedal platform?
    - best MIAB?
    - what Vox alternative?
    - guitar prices these days
    - Essex Recording Studios' latest eBay listing...
    Long exhale of breath.... I'm going to have to try a Page aren't I?! Why the silly prices? Is there a waiting list or summink?
    I see, that's tricky and it's probably all about context - are you playing in a band/with a backing track at decent volumes? In case not, I think we get very nit-picky about tones when we're at home practising. I find that what works in one context isn't necessarily best in another. When you're at stage volume, distortion is distortion to some extent. The nuances seem to diminish.
    That said, the best edge of break up tones I have come from a Mooer Blues Crab, which is a slightly darker sounding Marshall Bluesbreaker clone. It's kind of an MSG pedal - it just makes everything sound smooth and sparkly. I also have a TC Cinders, which is a Boss Blues Driver clone, and that does a nice thing too, although it sounds more like a 'pedal' to me. I've been through many pedals and kept these two...if the Cinders was expensive, I would probably sell it. I've also got a H&K Tube Factor which can do edge of break up, but it's less forgiving than the Blues Crab.
    Yes, you're right about context. But I'm a big believer in gear that inspires you to play. If a pedal doesn't give me a bone, it's not for me, even though the audience can't tell the difference.
  • MajorscaleMajorscale Frets: 1566
    See, the Page is very nice, but it’s not transparent to my ears, it adds a lot of warmth/thickness/lows/muddiness(?) to my ears and I would worry it doesn’t cut through as well as say a Benson Preamp would do. Edge of breakup is lovely on Page too, but not sure how it’d fare live.
    Not really! When I got mine recently it was three weeks tops.
    I think traditionally there maybe WAS a long wait so used prices rocketed due to sheer impatience.
  • beed84beed84 Frets: 2441
    That's good to know. Everyone seems to drop their trousers over the Page, so I'm going to have to try one as well. That said, the demos I've seen are very impressive.
    However, is there an advantage having the standard Page over the DS version? From what I've heard I like the Page DS and Squire combo, but would probably want to use and get the most out of the Page on its own too.
  • SassafrasSassafras Frets: 30320
    When I think of transparent edge of break up, I automatically think of the Xotic RC boost.
  • BradBrad Frets: 674
    The standard Page is designed to go in the front end of an amp whereas the Page DS and Squire are to replace the preamp section of an amp. The DS and Squire can work as conventional pedals into the front end, but the output is incredibly hot and I don’t think you get the best out of the pairing when going into the front end.
  • EricTheWearyEricTheWeary Frets: 16327
    - best MIAB?
    My Looking Glass is gathering dust, getting to be on my bucket list to plug the big(ish) pedalboard in again. It's a bit of an arse of a design if you like to tweak things on a gig, shiny pedal with concentric knobs. But an overall very versatile OD, I remember having to cut the bass back when using it which is something that rarely happens with ODs.
    Thanks @Brad . That's saved me a lot of money and getting the wrong one! A standard Page it is.
  • bbill335bbill335 Frets: 1391
    bd2 for me. it *literally* cuts bass, but what i've found is, it means that when you switch off the bd2 your amp is set correctly for a nice & full clean sound. switch it back on and you have *qualitatively* the same sound/tone, just with however much distortion you've set on the pedal.
  • Fishboy7Fishboy7 Frets: 2248
    Edge of breakup is a bit like my marriage :)  Natural and transparent not so much
    EQD Special Cranker
    Nice!
    That's basically how I use mine. I like it a lot.
  • As previously said, it depends on how you play, your guitar and your amp.
    When I'm using my Strat in the neck position into my AC30 clean, the Lightspeed adds a beautiful crisp, touch sensitive break up, whereas if I switch to the bridge pick it can sound too bright and fizzy, but kick in the Nobels ODR1/mini instead and gives it a far more suitable fuller rock sound.
       And then my Box of rock works better with my AC50/335 rig.
    ‘It is no measure of good health to be well adjusted to a profoundly sick society’
  • fastonebazfastonebaz Frets: 4153
    A steal At £435  !!!
    Kingsley Page DS Tube Boost V2 2017 - Present - White https://reverb.com/item/68434628
