I guess if you really want wireless audio you would have to get a Bluetooth receiver with USB out.
There is info about this in the manual.
https://line6.com/data/6/0a020a40152f865e216d6d6b24/application/pdf/POD%20Express%20Owner's%20Manual%20-%20English%20.pdf
I wish I never sold mine TBH.
I'm sure for some people it does all the relevant things they'd want from an M5 or an HX One, but it seems to me like a totally different beast. The vast majority of players will want a POD Express or an M5/HXOne, or one of each for different things, but I can't quite picture the scenario where I'd be dithering between the two.
I am hugely picky about compression for bass being absolutely perfect for me. Everything else I can work with, but the compression has to be spot on.
soundcloud.com/thecolourbox-1
Back up rig
Multi effects
Presets
Tap tempo
Expression pedal/external switching options
Tuner
Looper
USB Recording Interface
Headphone Practice Solution
Input, left/mono output, right output, expression pedal / external footswitch input
https://line6.com/data/6/0a020a40152f865e216d6d6b24/application/pdf/POD Express Owner's Manual - English .pdf
For those millenials out there who aren't aware of the notion of RTFM, there will be a video on TikTok later featuring a young person saying things like "OMG Line 6, you nailed it" coupled with some 8-bit graphic overlays.
USB Inputs 3-4 routed into the first block (distortion on PEG, compressor on PEB) for reamping
USB Outputs 1-2 to your DAW or mobile device for recording with processing
USB Outputs 3-4 to your DAW or mobile device for recording dry for reamping later
