JHFC, his voice is almost as good as it used to be.
Shockingly good this time. What a pleasant surprise. Great gig.
@EricTheWeary Biff and Rob both sounded pretty damn good I think, although at high volume it's sometimes a bit hard to make out the whole melody and you just hear the high notes...
Vocal shared duties and reinforcement will come from Whitesnake keyboardist and one time Mr.Big Tribute lead singer, Michele Luppi - by his own admission, this once fine vocalist who was touted for Toto, admits his voice is knackered.
What do you do? Pull the gig/rest of the tour and or Plan B? ^^^^^
I didn't realise Eric Martin had morphed into Brian Johnson...
https://www.instagram.com/p/C4t4QLGIYCL/?igsh=MXB3NGt2cDV1dmYwcQ==
(** Let's face it, as an audience we were nearly all older people...)
Had a couple of trips to stand behind the soundman to see if sounded any better, it didn't and the last time I did it there were only a handful of people stood there.
If you were towards the front you probably wouldn't have noticed, but stood at the back there was a steady stream leaving all night.
