What does your gigging amp weigh?
  • JetfireJetfire Frets: 1696
    Head 22 kg + cab 36,5 kg
    or combo 30 kg
    What cab is that? I'd guessing something like a 4 x 12?
  • chrisj1602chrisj1602 Frets: 3993
    Fender 68 Deluxe Reverb… 42lbs/19.05kg apparently.
    I did have a couple of Tone Masters (Deluxe Reverb and Princeton) and a Blackstar St James before this, so I’d forgotten what a full fat valve amp weighed!
  • guitarmanglerguitarmangler Frets: 594
    Yamaha dg80. 25kg or 55lbs.Its a 1x12 solid state combo with a single handle !
  • KeefyKeefy Frets: 2301
    octatonic said:
    Matchless Lighting Reverb combo.
    50lbs/22kg.
    Same here but at least one of those figures has to be approximate because 22kg = 48.4lb!
  • stickyfiddlestickyfiddle Frets: 27206
    Tonemaster Deluxe Reverb 11kg ish
    Bad Cat Cub III 15R Combo 20kg ish
    I don't take both!
  • EricTheWearyEricTheWeary Frets: 16299
    When I last gigged my Laney combo which is 24.5kg.
  • snowblindsnowblind Frets: 311
    Laney VC30 212 with HiWatt speakers. Pushing 28Kg or thereabouts. Alternative would be the Epiphone BC30, also 2x12 and about 26Kg.
    It would be nice to have a gig I could take the HiWatt to but a DR103 plus matching cab weighs as much as a small planet.
    Gone are the days when I could comfortably(sic) move a 4x12 on my own.
    Old, overweight and badly maintained. Unlike my amps which are just old and overweight.
  • KurtisKurtis Frets: 736
    Mine's like well heavy.
  • DiscoStuDiscoStu Frets: 5551
    edited March 24
    ecc83 said:
    "Blackstar HT Stage 60 2x12. 30kg.
    I need to get rid cos my back is fucked. "
    Be careful what you wish for Stu! I don't know your genre or venues but that combo is capable of serious sound levels, despite the name it will chuck out 100W if really pushed.
    Maybe a head+cab alternative?
    Dave.
    I love it Dave, but it's too damn heavy. It lives upstairs when it's at home and I really struggle getting it up and down the stairs, in the car, out the car, etc. I use a trolley if I'm on the flat but any lifting is problematic as I'm currently signed off work with a suspected herniated disc.
    I've been rethinking how I move forward.
    If I stay with Blackstar then St James 6L6? Amped 3?
    The new Line 6 Catalyst CX 100 might work.
    Helix + FRFR, maybe the new Fender ones.
    Spark Live looks ideal but I wonder how buggy it will be cos I hate using the app on my Spark 40.
  • fretmeisterfretmeister Frets: 24601
    1000watt bass rig.
    16.7 kg.
    That’s 2 cabs and a head.
    Modern tech is amazing.
    Schnozz said:
    Does anyone use anything to get theirs up and into the boot of the car?
    God no!
    If it needed that I would never own it in the first place!
  • distresseddistressed Frets: 540
    or combo 30 kg
    Marshall 1960A.
  • hoofheartedhoofhearted Frets: 37
    edited March 23
    It's a ToneMaster Deluxe. So, like, nothing.
    (The spec sheet says 23lbs or 10.4kg)
    Same here it nearly floats out of the car when I open the boot  =)
  • JonathangusJonathangus Frets: 4581
    Marshall 2104 in a head shell, about 15 kg.  Plus 12 kg or 13.5 kg depending on whether I take my 1x12 or 2x12.  And I have a trolley.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
    Yep - mine weighs considerably less than my pedalboard!
  • ScreamingDaveScreamingDave Frets: 558
    edited March 23
    Marshall DSL40CR @ 23kg
    Seriously thinking of going over to TC Electonic Jims 45 Straight into the PA, but then I’d have to take a full PA to rehearsal!
  • It's a ToneMaster Deluxe. So, like, nothing.
    My TM Princeton is even better - a hair over 9kgs!
  • ecc83ecc83 Frets: 1639
    Dave.
    If I stay with Blackstar then St James 6L6? Amplified 3?
    Well, if you are thinking of those alternatives Stu then the Club 50Mk3 head and a 2x12 cab should give you all the power you need and AFAIK the Club is virtually the same circuity as the Stage 60?
    You can of course double up on cabs for a really big venue.
    Dave.
  • I used to gig a valve combo but had some neck and  back issues and bought my Milkman Amp 100... at less than 1.2 kg it has been the perfect recovery solution and is flexible enough for every scenario I need it for. I think about going back and then wonder why.
    God no!
    Our bassist had an Ashdown combo. He couldn’t get it in the back of his car without assistance from his neighbour and a special bit of carpet to protect the paintwork/combo. Then needed help from a band member at the gig to get it out the car onto a trolley.
