You mentioned that the bridge came off, is that definately seated properly? Maybe one of the pivot screws needs adjusting?
I am a little confused re the buzzing, if you raised the relief and saddles so it's really high, I don't imagine it can be the frets?
Could it be something under the pick guard resonating or a loose trem spring?
It seems to me that the buyer is being extremely reasonable under the circumstances.
UPDATE - the seller has kindly agreed to pay for the setup. I'm still waiting to hear from Suhr as to what the green is all about but it should (!) be cosmetic only so if I can get it set up perfectly then it's all set. Thumbs up to the seller for agreeing to this.
My YouTube Channel
My YouTube Channel
My YouTube Channel
In the great scheme of things, the cost of making and fitting a new neck is probably less injurious to their business than having someone pointing out that the neck on their Suhr has a strange discolouration.
This shows a keen business brain and integrity on JS's part. Any company that works that hard to protect its reputation deserves to succeed.
My YouTube Channel
IIRC Suhr doesn't like figured necks as they are less stable.
My YouTube Channel
