My YouTube Channel
My YouTube Channel
OK, strictly speaking that's just to get them off the ground, I couldn't go upstairs like that. I'm not Superman . But I can easily go upstairs with one. It's an easy lift for an amp that weight because it has nice handles, smooth rounded edges and is compact and well-balanced.
If you're just not up for lifting that sort of weight, either get the ID60 combo or a head and 1x12" cab and make more trips. You can get the ID60 as a head which weighs next to nothing, or the ID100 which might be a better choice if you play loud since they will only give maximum power into 4 ohms, and most 1x12" cabs will be 8 or 16.
(If you're interested, a friend is selling a Montage 1x12" with a Classic Lead 80 in it which isn't too heavy.)
Yes, you will need to put a boost in the loop if you want it to raise the volume. Or just use one of the channels for a boosted lead sound?
My YouTube Channel
https://www.youtube.com/watch?v=RhXDmxEAM6I
The montage will probably be nicer than an ID cab. But some modelling amps actually prefer the shite speakers the cheap cabs come with, rather than the rather posher, nicer speakers other cabs get. So... Horses for courses I guess.
Montage cabs are supposed to be good, there is an import range and a UK built range iirc.
The classic lead 80 is a nice speaker, though I'm pretty much sold on v30s and t75s or whatever they're called. Mix them and listen to the awesome crunch. But maybe not with a modeller. Maybe.
I tried the ID60 head through a crap Marshall Valvestate cab and a 'good' Marshall 4x12" with G12T-75s, and it was better through the cheap cab! But the 75 is quite a hollow, slightly thin and buzzy-sounding speaker so it might not have been the best comparison. Unfortunately I didn't have a V30 cab to hand or I would have tried that for sure.
Be careful about the impedance - the ID really needs 4 ohms to work at it's best. If you were going for a head and a non-Blackstar cab, that's why I would probably pick the 100, to make sure it didn't run out of puff if you use it with an 8 or especially 16-ohm cab.
I agree about stereo being wonderfully lush, but in a stage mix it doesn't really work so well so you may not miss it as much as you expect.
You could look out for a used Vox Valvetronix with Neodymium speakers. The 150 watter has loads of amp models and effects, and plenty of power. And weighs in at just over 12kgs.
I quite like the tone of them too. More than good enough in a band mix. My AD15 has had a hiding and is still going after about 5-6 years (I use it flat out at my local jam night).
My YouTube Channel
My YouTube Channel
My YouTube Channel
My YouTube Channel
