@Megii. I held a brand new stanley blade flat and drew it back and forth until the wood began to expose, then coated in a good dose of stripper and left it to work. Then I used scotchbrite and the blade again for the stubborn bits that were left to remove the remainder. It took hours and I wouldn't advise it! It was a case of needs must for me though.
I'm still thinking about a TMO FAT like @Loobs has just got and I know jd feels the love for them too.
Manchester based original indie band Random White:
https://www.facebook.com/RandomWhite
https://twitter.com/randomwhite1
@simonbeckwith, it's a solder lug. A very kind forumite gave it to me (Steve Robinson, revered Manchester Guitar Tech), but you can buy them here for the princely sum of 13p each:
http://www.digikey.co.uk/product-detail/en/910/910K-ND/317251
Again, it wasn't my idea to simply put the bridge pup screw through the solder lug screw hole. I googled it (as with most of the jobs on this build!)
Yeah, I prefer Radio too bro. [/quote]
Depends on the station. Commercial stations rarely play anything heavy enough for me
I think I could do it. It's just that the tech only charges £35 and as it's a build as opposed to a factory job I'd like an expert to give it the once over if that makes sense?
