Next Project ... opinions? ... & updates!
  • cacophonycacophony Frets: 385
    your local branch of "clamps `r` us" must do steady business!...
  • WezVWezV Frets: 16780
    1st rule of guitar building club.... Buy more clamps!
  • Shark_EyesShark_Eyes Frets: 377
    Glad you went with a centred join, it's going to look great.
    I like the look of this @TTony. It's going to be a corker! Andy
  • monquixotemonquixote Frets: 17668
    Brilliant work Tony
    Can't wait to see what it looks like.
    I think I'm going to have to drop your box of bits round so I can see your new toys :)
  • TTonyTTony Frets: 27681
    And give them a test drive!
    Only had a couple of hours today   :(
    Clamps off and shape the top to match the body with a bearing guided cutter
    This little pattern/template is going to help me cheat, and save a chunk of carving time
    Now I have a consistent thickness ledge / edge round the top of the guitar - taking about 7mm off the thick part and 0mm of the thin end of the wedge;
    Flip the pattern over and do the other side, and this is as far as I got today.
    Still plenty to do, but the heavy power-tool woodworking is just about done.  I'll do the roundover and the cavities (p'up and control) next, and then carve, carve, carve the top, followed by about 3 weeks of sanding it all!
    But it's looking like its coming together ok.
  • guitargeek62guitargeek62 Frets: 4164
    edited March 2015
    :D
    Looking good  from here, @TTony
    WezV said:
    awesome stuff  - seems to be working out quite well so far
    whenever I have done similar neck slots in caps i have routed it with rounded corners and squared up the corners by hand - usually means I can use a neck pocket template to do most of the work.
    normally i am doing it to attach full frontal a cap to a through neck guitar, rather than trying to save an incorrect neck angle.  its mostly what i did on this one, but it needed a bit more shaping by hand because of the angles
    By the way, @WezV, that carve is aspirational  :)
    Feck, feck, feck, feck, feck.
    Twice.
    Spent a good few hours yesterday carving the top, and sanding and carving and sanding and carving and sanding.  It was (note, "was") looking good.
    This is before final final sanding
    And here it is done to 120grit.  Looking nicely rounded and smooth.
    I was quite happy.
    Today, I'm a little tired, but I've got a couple of hours, so I thought I'd do the last of the power tool work and prep it for finishing.
    The top is still quite thick over the control cavity, and I'd need pots with 20mm shafts, so I'll just take rout out the cavity a bit so that normal pots will fit.  Simples.
    Feck #1.  That's the end of the control cavity poking through under the carve.  Feck.
    I'll have to think about that one.  But I'll carry on and get the pickup cavity routed out.
    Now, that's a bit odd.  I wasn't necessarily expecting to get the new cavity bang-on the old one, but that's a bit too much of a difference for me not to have a little worry ....
    .... and Feck #2, I've put it in the wrong place.
    Measured the scale length to the 12th fret (12.25") and doubled it to get the line for the bridge (at 25.5") and work back a bit to place the cavity ... except 2 x 12.25" isn't quite 25.5".
    I've now shut up the workshop and will do something else today.
    Initial thoughts are to use a piece of the offcut maple to make a piece to fit in the wrongly placed cavity - make it really, really, accurately so that it's a very tight push-fit - and glue it in place.  And then I'll either have to veneer it to hide the feck-up (veneer would also handlily deal with the extra ventilation hole for the cavity cover) or work out how to fill that hole as well and then use a more opaque finish than I was planning to hide both of the feck-ups.
    After the hours I spent carving and sanding the top yesterday, I'm really not very happy.
    Having looked at it again, and given it some more thought ...
    It's just another opportunity to solve some problems and develop some skills.
    I'm going to cut out a larger area than the pickup cavity.  Firstly, it's an awkward shape to cut accurately, secondly the corners of the (wrongly placed) cavity are close to where the bridge posts will go, and I don't want those to go into a weakened area.
    So, my thinking is to cut out a larger area with straight lines, and drop in a replacement piece cut from the offcuts, making sure that it's a real tight fit.  Much of the replacement piece will still be hidden by the bridge and pickup, and looking at it, the grain pattern is a reasonable match.
    Still got to think about the extra cavity ventilation hole though.  I'm thinking that I'll glue another offcuts piece underneath the hole in the cavity, and then fill the last bit with a bit of sawdust & glue.  Unless someone tells me better.
  • SargeSarge Frets: 2429
    A top mounted jack socket to cover the hole? or is that too far out?
    Think it'd look too odd.
  • steamabacussteamabacus Frets: 1268
    So, solid colour finish now? The edge hole could be bursted over but the repair around the pickup/bridge seems more problematic. Goldtop would look good.
    Glue a new bit on the inside of the cavity
    What was the scale length then, if I made this Gibson scale length its likely to be 24 5/8" or 24 9/16".... But I could have placed bets on making this 25" it was a few years ago now
    This is fast becoming an opportunity to learn new skills, so perhaps it's time to get a spray can or two and learn to DiY spray, rather than the Wudtone that I'd planned.  Or maybe it's an opportunity for some sort of weird scratchplate.  I'll think on that some more.
    I'll triple-check before I drill/cut anything else, but I'm pretty sure it's 24.5" scale length, although very possibly 24 9/16".  Certainly not 25" though.
    Having measured, I've got an offcut that's just about big and thick enough to fit in, once I've straightened the edges up.  I'll rout out a hole that's a bit bigger than the p'up cavity to make sure that it's got a firm base, and that any joints are far enough away from the holes for the bridge posts.
    But that's a job for another weekend.
    A Zemaitis style oval plate around the area did briefly come to mind - not sure how that would work with the carve, though?
    I don't remember to be honest - the intention at the time was to build something with a similar feel to my (then) '63 SG Jr, so I imagine we'd have gone with a Gibson scale of some sorts.
  • JalapenoJalapeno Frets: 6398
    And possibly some french polish skills to join the grain line up.
    Feedback
