So what actually is the heaviest combo?
  • ICBMICBM Frets: 72677
    timmysoft said:
    I've never really struggled, but then I'm retry fit, over 6 foot and 14 stone. I can actually carry two 412s at once, I don't know how I found that out but it used to be a handy trick.
    At a gig in the late 80s at the Edinburgh Playhouse, I saw the support band's roadie come on at the changeover and carry their entire Trace Elliot bass stack - I think 1x15" and 4x10", although it might have been two 4x10"s - with the head still on top, by picking it up by the side handles of the bottom cab. He looked like a big bloke, but… f***!! That lot must have weighed well over 200lbs, even the heads from that era aren't at all light.
  • seany65seany65 Frets: 264
    If the heaviest combo is not also the most expensive, then there's summat wrong somewhere.
    :P
  • vizviz Frets: 10732
    Carvin legacy combo: 28kg
    Carvin legacy 4x12 cab: 42kg
  • richhrichh Frets: 453
    Nomination for the Seymour Duncan convertible 1 x 12.
    I'm not sure the actual weight, but I tried lifting one, and it was a beast!
  • CirrusCirrus Frets: 8495
    edited March 2015
    The heaviest combo is whichever one you're trying to lift into the boot of your car at 2:30am after a long gig when all you want is to be in bed already.
    I think my Mesa Stiletto Ace 2x12 is 88lbs, Above a certain weight it's basically irrelevant anyway because you're not going to move it on the level without wheels and you're not going to lift it up stairs without help. I think the heaviest I'd be happy to lift about on my own is an AC30 combo at ~70lbs, and that only because it's got three top handles and it's a relatively shallow open backed cab so it's easy to bear-hug to lug it round.
    I have a Fender TRRI and a Matchless DC30 (moezambeeks old one as a matter of fact)
    Before every Gig I gaze upon them... then my eye falls on the two rock Jet 20 combo....
  • crunchmancrunchman Frets: 11472
    Trace had a bass amp with valves in.  I think there was a 2 x 12 combo version.  That has to be up there.
    edited March 2015
    I don't think the combo version is the full valve power amp - it's the hybrid one, so it's not as heavy. I could be wrong… I borrowed one briefly which was the hybrid, but if they did an all-valveone as well it's only the 200W one so not that heavy. The combo is a 2x10".
    The V8 400W head is a monster though, but not quite in the SVT league for sheer weight. Nor, sadly, for robustness. I used one for a while once, and I've worked on a few more - just too flimsy to be really reliable unfortunately.
    I have heard they were stupidly heavy.
    They weren't. A friend of mine had one, it was no more than medium at most.
    The spec says 57lbs, which sounds about right from memory and makes it lighter than my solid-state Peavey Special.
  • photekphotek Frets: 1469
    edited March 2015
    Fuzzdog said:
    Heaviest amp I ever had was a silverface Fender Quad Reverb I borrowed for a while.
    Gorgeous tone, but you didn't want to move it very often. :))
    I gigged a Quad Reverb for a couple of years, I can't believe I managed getting around with it. Lifting it into and out of a mk2 golf boot was a serious mission. Website says they weigh 90lbs, Mine was close 100lbs on the postage scales.
    I also have an Acoustic Model 165 (80's Boogie copy) that weighs 70lbs which is a lot for a 1x12 combo!
  • JayGeeJayGee Frets: 1269
    Anyone know what a Super Six weighs?
    I had a Peavey Deuce for ages, which wasn't very big but weighed 100lb-ish, lugging it up 7 flights of stairs to my flat after a gig was never much fun.
    98lbs but I bet they are heavier than that, my quad was about that weight.
    I think the Quad might be fractionally heavier than the Super Six actually - the Six does have two more speakers but they're much lighter than the ones in the Quad, and although the cab is taller there's not a lot of extra material.
    I don't think I've ever come across both together so I could try lifting one with each hand :).
  • As suggested earlier, the Egnator Tourmaster Combo - which is 97lb so up there.
    Chuck Berry had the right idea.
    He didn't like Keith Richards setting up his amp though... Keith made a mistake allowing him to use something as loud and bright as a Twin.
    A bass player I know always said that the best bass amp is "someone else's PA" :).
  • longilongi Frets: 95
    The Laney AOR Pro Tube 50 watt combo is pretty heavy as I remember it. I remember picking it up and having a F$%k me that's heavy moment and I work out!
  • stedsted Frets: 259
    My old Mesa MV was pretty unwieldy and heavy for a small 1x12, my Matchless head is insanely heavy for its dimensions, god knows what a 2x12 must be like from those guys.
