Very Francis Dunnery in bits. Sounds great
Are you running cab models in to the FX return or do you have them disabled? That's pretty much my plan for live use, don't want to go direct to FOH when the other guitarist is still running a big valve amp as backline, maybe I'll get him to concert too Need to stop dithering and get one ordered before prices go up.
Does anyone have any idea if the Warranty is transferable if I bought a used one? There a few on ebay at the moment
A bit confused (I'm easily confused) in the previous post you said 'it was just the Helix Cali Lead with a Minotaur in front and some of the new delay into the effects return of the Cornford ' and then in the last post it sounds like you're using the Cornford and just using the Helix mainly as an effects processor.
When running in to the FX return are you using poweramp/cab modelling? or just the Helix pre-amps?
Cheers for the responses, much appreciated
Bass drives. Darkglass types. And the synth needs sorting.
The Digitech Bass Synth Wah is still the daddy at the moment.
And even when running in full 4cm in effect, when choosing a Helix amp model in place of your real amps preamp you are in fact just going into your amps effects return.
i can't really use the Cornford drive channel at home, even if the neighbours are out its just too bloody loud to get it anywhere near its sweet spot!
More flexibility in parameter control, so that it'd be easy to have the expression pedal turn the wah off at heel-down, and on as soon as the pedal is moved up a bit. That was a doddle in the VG-88.
A set of internal LFOs that can be assigned to any parameter.
An internal envelope generator that can be assigned to any parameter.
In terms of effect blocks I'd like some more basics. A notch filter (probably doable with the parametric EQ, I suppose), a more seamless barberpole rise/fall mode for the LFOs, particularly for the phaser. A model of the Alesis ModFX stuff - particularly the Philtre and the Bitrman, but also the vocoder.
And I'd really, really like a model of the Yamaha UD Stomp. I know it'd take lots of DSP and it'd be more complex to work with, but that unit was so enormously capable... and with the Line6/Yamaha link you'd think it'd work out nicely.
All that said I'm still not really pushing what can be done in terms of building sounds - partly because I keep getting distracted by playing guitar and cello through it.
I'd love to hear that!
Would love for some more reverse delay options like PS3 or Empress mode 7...
Wave LFO like the reflex and dd500 would be nice
I'd also like to be able to apply a delay to a cab, like you can in Sgear's convolver.
Pan law woul dalso be nice.
But if they left it as is, I wouldn't be crying. 2.0 was a damn good update.
It does make me wonder what else L6 have up their sleeve
it was a lot of stress but it's put it back in the set
its one of the only ones where I needed the other guitarist
ive now replaced him entirely with the Helix
its just like him
not too bright
I have to step on it to get results
i spend most of my time carrying it
