Clarky and the Helix
  • ClarkyClarky Frets: 3261
    Clarky said:
    my biggest concern is having to change preset mid-song: double tap [bank then select preset]
    cos that's certainly not something I could live with.. not with the sort of crap I play live..
    Why would you have to do that? Preset mode lets you access up to 8 presets instantly, with one switch. Or if you put your presets in order, the UP/DOWN switches can be set to preset up/down (or snapshot up/down) and access all 128 presets in a setlist sequentially.
    You can also assign Command Center messages to recall any setlist, preset, and or snapshot in the unit, so with a short MIDI cable, any preset can go to any other preset.
    I've tried 'song' methods in other units before..
    it's good provided that you don't make a mistake..
    I'll have to give this some thought..
  • fretmeisterfretmeister Frets: 24401
    He's maxing the DSP - there will be latency silence as it loads.
  • SporkySporky Frets: 28426
    But with Native he wouldn't run out of DSP in unlimited mode. Unless I've misunderstood it?
    I think it's only got the same number of block slots though?
    as with all modellers.. changing preset takes time for the DSP's to load
    and ambient tails get chopped
    this is why I try as best I can to fit the entire needs of a single song into a single preset
    in the VG-99, there was one song that needed 2 presets..
    I managed to overcome it by finding the optimum moment to change preset
    in this case both presets had the riff tone in common, the riff tone is bone dry so no tails
    there was a moment in that song during the transition from the 2nd verse to the 2nd chorus when I could make the switch invisible because of what I was playing at that moment
    in the case of the Helix I'd make all my presets as best I can and then find out in the set where I can make the change..
    I will absolutely avoid mid-song preset changes unless I have absolutely no choice..
    and then in those circumstances as previously described, go to some lengths to find the optimum location to do it..
    this means I need to be in snapshot mode.. which means hitting bank then preset to switch..
    I'm not fond of 'song mode' or placing presets in sequences due to the lack of flexibility..
    make a mistake and you're lost for a moment.. and then it'll take too long to get back on track..
    the stuff I have to do live with hands, feet and mind is stuff enough… lmao
    from a performance standpoint it has to be easy, quick and reliable
    so… all that painstaking effort in the config pays back by making the performance side of things work well and intuitively
    and the same number of paths.. which is in itself a bit limiting..
    but as I learn the unit I think it's not something I can't overcome with a little creativity
    What is this unlimited mode?
    Native usually limits the DSP to the same amount as the hardware units.
    If you have a monster PC you can turn off those limits. So not really unlimited - but only limited by your PC.
    So if you've got an i7 7700 overclocked and all the Ram in the universe you can go nuts!
    Stood on stage at an open air festival with a laptop and a guitar jacked into an audio interface
    hmmmm
    it's just not rock'n'roll lmao
    hmmmm
    Not even with something like this?
    Just think of the screensavers you could use as miniature light shows.  lol
  • RolandRoland Frets: 8724
    Nice fly rig. You could always have a selection of 4x12s in your rider.
    I've seen this posted before but I can't see any mention of it in the manual or the specs
    A quick look around the plug in doesn't show it as an option anywhere either.
    how do you enable it?
    I'm fairly sure it's not available yet and it's just something they're talking about adding later on.
    Ah - there's been a lot of FB chat about it - I thought it was here already
    Phew
    thought I was losing my marbles!
  • Hardware Compatibility Mode—or rather, the ability to turn Hardware Compatibility Mode off—is forthcoming.
    Chief Product Design Architect, Yamaha Guitar Group | Line 6 | Ampeg
    Very cool feature
    A lappy sat on top of a wall of Marshalls..
    I think this may actually be against the law
  • gearaddictgearaddict Frets: 895
    It's only a matter of time...I remember when I saw the USB port on the front of a H&K Coreblade thinking "well, that's not very rock, is it?". Now I'm going all digital. Using massive transformers and valves is starting to feel a bit...well, environmentally unfriendly...I'm just getting old.
  • trolleytrolley Frets: 88
    edited August 2017
    Surely no more against the law than having a wall of Marshalls - none connected - and using a 1x12" offstage? Why not a wall of FRFR's - on poles?
