Amp Demo Day - Nottingham 30th May. ITS ON!!
    edited April 2015
    EDIT:  This post makes no sense now, but we had a temporary glitch, which this was in response to.  It is explained by the next few posts BTW.  The forum has evolved into a self protecting organism, which is pretty spectacular IMO.  Well done @TTony @DigitalScream @Monquixote  :)
    ~ it originally read, in response to a (temporary) ban to Hywelg's user ID~
    "Extraoridinary, I can't imagine what on earth has happened here.
    One of the good guys down and out ?!?
    @digitalscream ~ or anyone care to comment ?"
    3 ~ 2 ~ 1    and back in the room      :D
  • TTonyTTony Frets: 27718
    edited April 2015
    I can comment - because I'd noticed something was amiss before seeing this post!
    The hywelg userID was banned due to a false positive based on an IP addy (a mobile network IP) used by our well-known scammer.  It was an automated system action rather than a modmin action which is why there was no message to @HywelG @HywelHarris.
    So, with genuine human apologies to HywelG, I've unbanned your original ID and will delete the new userID as soon as you say so.
  • hywelghywelg Frets: 4305
    @TTony, Does that mean we're all at risk if we log in via a mobile network?
    Thanks JC....
    Thanks JC....
    There's always a risk, but it's pretty small.
    If you happen to be particularly unlucky and have the same problem again, email me at ttony@thefb.co.uk (incl your userID) and I'll get it sorted.
    Now, just PM me with a copy of your passport, driving licence, birth certificate and bank details so that I can verify that you're not a well known architectural photographer ...
    :D
    I'll delete your brief reincarnation as HywelHarris.
    edited April 2015
    OK guys and gals,
    How about Saturday the 30th May.?
    Let me know, what you will be bringing amp wise, indeed pedals also if you're happy for others to demo them and I'll update in post 2 above. I'll try and sort out a temporary pedal board so we can add stuff in easily (though I'm not sure how easy it will be to sort out different supply voltages).
    I'll also try and sort out a long speaker jack-jack cable so we can try amps thorugh different cabs without having to move things around too much.
    Thats the real me so go easy !!!
  • LodiousLodious Frets: 1947
    30 May should be good for me, I can bring a Bad Cat Cub3 and/or a Two Rock SP22. Where is the practice room located?
  • John_AJohn_A Frets: 3775
    Sounds good to me, can bring a Dr Z maz 18, an AMT Stonehead and a homemade JTM 18
  • Adam_MDAdam_MD Frets: 3420
    edited April 2015
    30th works for me I'll bring a Mesa Transatlantic and a Zilla cab if anyone wants to check one out.
    Anyone that wants to can have a play.
  • RolandRoland Frets: 8783
    hywelg said:
    OK guys and gals,
    Isn't that the date for Knackered Jack and the Resistors in Walsall?  @Alnico
    edited April 2015
    OK, possible conflict, though I think the focus of the Walsall event will likely be in conflict with a bunch of hacks trying out different amps.  @digitalscream ; @paulmapp8306 is 30th a problem for you chaps?
    @Lodious @Adam_MD and @John_A are OK for the 30th.
    Anyone else interested? @ChrisMusic not sure if you were  just commenting.
    I have a non-forumite interested too.
    30th is fine for me :-)
    Ok for me
  • Will be a bit of "Ill have to see on the day/the day before" as plans with the wifes work changes.  May be only part of the day - or all of it depending on her shifts.
    As for gear,  If I make it I can bring the AFX2 (again with Zilla cab) - but dont have any FRFR set up unfortunately.   I can also bring the Fender Machete is anyones interested.
    Guitar wise - whatever people want to try.  I can bring a couple from:
    PRS CU22 with Mules
    PRS CE with P90s
    Tele with Broadcaster PUs
    Select Strat
    Suhr Modern
    Most are readily available so maybe not of interest.  If no one has any preference it will be the strat and the Suhr.
    I was just getting involved, as reports of your somewhat early demise seemed exaggerated, thankfully.  Just doing my bit to show solidarity & to help   :)
    I have been keeping an eye on this thread as I quite fancy the idea, so you can count me as interested, but it depends a bit on how things are at the time.  So I will keep that as 'interested' for now, and talk further closer to the time, if that's OK ?
    There are a couple of things I can bring along if I can make it.
    Sure @ChrisMusic, I dont want it to be a formal affair anyway.
  • paulmapp8306paulmapp8306 Frets: 850
    Any updates/conformations on this?
    I have a tentative "go ahead" from the wife :)
    Nothing to report, I have secured the rehearsal studio so as long as we have participants it will be ON
  • mrkbmrkb Frets: 6934
    edited May 2015
    I fancy coming along for a bit if possible - don't have an amp, but have an AxefxII, or can bring a Atomic CLR FRFR to use with paulmapps AxefxII. Is there a rough time/date for this. Is it daytime or evening?
    Karma......
    Ebay mark7777_1
