Noise wise, there is some but I checked it against my Plexi Drive Deluxe and it's the same as that so I'm no longer too worried about the pedal being faulty.
Using it with the Dirty Shirley 40 which has its volume on 7 and gain between 2/4 it sounds fine no issues with noise with a full sweep of gain dial.
If I run the Shirley with the gain on around 7 then we're into complete mess with feedback at pretty much anywhere with the pedal being on.
My intention was to use it as a faux second channel for the DS which seems like it should be able to do with a bit of fine tuning.
Sounds wise I've never played a BE amp so I'm unsure on how close it gets you to that sound but it was able to dial in some early Metallica and Maiden which id not been able to quite get right with the DS on its own.
I will try it in my McFly later to see how that amp likes it.
Ive been using my Archer to boost the Shirley and that works better for that job.
I think the trim pots at about 9 after fiddling as well.
Looks like the same is happening the helix and fx8. They are hitting low 700s too.
Someone suggested running it in the fx return of the amp for a more organic tone rather than the front end
Mines arriving tomorrow. Looking forward to it
I'm not into pedals really but like the BE tone but no way im
paying for the amp as I only play at home these days and looks to be a solution.
Doesn't work well with my amp at all unfortunately and doesn't sound good
Not the end of the world and it sounds like a great pedal just not with this particular amp
The Marvel is a stunning, stunning pedal and works beautifully. The Amptweaker benefits from more controls, but I think the Friedman does too, can really fine tune to your tastes.
What amp?
