Obviously you see the point in baiting people to provoke responses similar to previous responses, but it's not really the point of having the kind of debate which, due to it's subject nature, is already prone to all kinds of silliness.
There's a difference between having a sensible debate and deliberately going out of your way to try and get a rise out of someone y'know
Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
I'll do some humility on yours.
Note phenomenon.
Come up with hypothesis that may explain it.
Test hypothesis.
Modify hypothesis.
Have other people do the same, and check you did it right.
If it survives an awful lot of testing, and makes novel predictions that turn out to be correct, it becomes accepted.
At the point where the evidence is overwhelming it becomes a scientific theory.
That's all it is, with a bit of paraphrasing. There's nothing to get upset about. Obviously it can only be applied to things that can be tested...
Or as @Drew_TNBD alludes to re @TheBlueWolf , maybe I'm just a bit of a hippy...
