That said, I have bought a DOD rubberneck in the hope that it replaces my DD500, which I'd like to keep at home.
Memory Lane Junior out. Nemesis in.
Difficult though, the MLjr does what it does amazingly.
Also, I may get a Neunaber Expanse and EXP, which although the WET is the big drawer, could potentially replace a Mooer Chorus and Boss BF-2 also.
Or, replace the lot with an FX8 or Helix and just retain a couple of juansolo drive pedals.
I'm at that stage where the whole issue is taking up too much brain RAM. I need the bad software uninstalling from my mind and a shutdown / restart cycle.
JM build | Pedalboard plans
Just to save a bit of space.
But when the next Helix firmware hits there will be loads more bass options so I might not need it at all.
When I get round to making a few more perfboard dirtboxes I might end up switching out the ones I have at the moment.
I might swap my CE-5 for a CE-2 or an MXR Analog Chorus but I also might not bother.
Semi-tempted to swap my Polara for an RV-5 or RV-6 but only for the sad reason that I quite like the idea of an all-boss board (or as near as possible).
Could potentially swap my Fuzz out and put a DS-1 on instead but I actually just have space to add the DS-1 anyway.
So I guess the answer is...erm, no, not really.
As a recent convert to the joys of the Dist+, what can you tell me about the Pork Loin and the OD-2?
On my not-a-board board (wah>fuzz>rangmaster), I'm gonna try swapping a Si fuzz (efe black acid) for a Ge fuzz (creepyface) and see how that works out.
The OD-2 is a low-gainer with a slight mid hump, I find it works very nicely for slide. It's only drawback is a lack of volume, you couldn't use it as a boost. I've had an OD-2 since they first came out so it must be doing something right (for my style, anyway).
This thread has reminded me I wanted a DS1. So I bought a DS1. Damnit GAS.
