Have you pedal on your board that you know you are going to replace in the near future?
DesVegasDesVegas Frets: 4610
What is it and what will it be replaced with?
«13
  • TeetonetalTeetonetal Frets: 7815
    Sadly, my philosophy appears to be buy first, think about it 2nd...
    That said, I have bought a DOD rubberneck in the hope that it replaces my DD500, which I'd like to keep at home.
  • menamestommenamestom Frets: 4727
    Memory Lane Junior out. Nemesis in.
    Difficult though, the MLjr does what it does amazingly.
    Also, I may get a Neunaber Expanse and EXP, which although the WET is the big drawer, could potentially replace a Mooer Chorus and Boss BF-2 also.
    Or, replace the lot with an FX8 or Helix and just retain a couple of juansolo drive pedals.
    I'm at that stage where the whole issue is taking up too much brain RAM.  I need the bad software uninstalling from my mind and a shutdown / restart cycle.
  • TC spark booster will be a/b'd with an Xotic EP booster (just to see if the hype is true) and the loser will be sold, or flayed and burnt at the steak.
  • or flayed and burnt at the steak.
    Could I have dibs on the resulting char-grilled steak?  I hear those pedals impart a unique and delectable flavour.
  • SporkySporky Frets: 28698
    I have a Touchprone MIDI clock generator that will disappear at the next Helix firmware update (as Helix will support MIDI clock natively then). Not replacing it with anything. Though an EHX 8-step would open up interesting possibilities...
  • fretmeisterfretmeister Frets: 24628
    I might swap my Darkglass VMTD for the standard VMT version.
    Just to save a bit of space.
    But when the next Helix firmware hits there will be loads more bass options so I might not need it at all.
  • english_bobenglish_bob Frets: 5167
    Actually no. I usually do, but at the moment there's nothing I feel like needs it.
    When I get round to making a few more perfboard dirtboxes I might end up switching out the ones I have at the moment.
  • UnclePsychosisUnclePsychosis Frets: 12959
    I might swap my CE-5 for a CE-2 or an MXR Analog Chorus but I also might not bother.
    Semi-tempted to swap my Polara for an RV-5 or RV-6 but only for the sad reason that I quite like the idea of an all-boss board (or as near as possible).
    Could potentially swap my Fuzz out and put a DS-1 on instead but I actually just have space to add the DS-1 anyway.
    So I guess the answer is...erm, no, not really.
  • SassafrasSassafras Frets: 30316
    Not permanent replacements but I often alternate between my beloved OD-2, MXR Dist+ and a Rat. Nothing knocks the Pork Loin off the board.
  • Not really and I find it oddly unsettling.  Ive hit a glass ceiling where swapping things in and out just seems a little pointless now.
  • JezWyndJezWynd Frets: 6116
    I've found the best solution for me very often has 'Maxon' written on it. Wth that in mind I'm tempted by the RTC600, though the Keeley Compressor Pro I scored recently is very nice, so I can't really justify it.
  • sgosdensgosden Frets: 1994
    Looking like Timeline, Mobius, NS2 and MD2 are to be replaced by Helix rack. EQD palisades is the only thing I haven't been able to match or improve on sound wise, so that'll sit in a loop.
  • Crowther Hotcake out... incoming Lovepedal High Power Tweed Twin
  • And maybe I'll send them both packing after a pedal try out this evening?
    As a recent convert to the joys of the Dist+, what can you tell me about the Pork Loin and the OD-2?
  • bbill335bbill335 Frets: 1389
    edited March 2017
    The distortron will go eventually, I just have a feeling about it. It sounds really good, just a little stiff? I'm getting kind of fed up with the re20 as well, and can see myself swapping it for something quite different (kilobyte/supapuss/an analog delay or vintage sim i haven't tried yet).
    On my not-a-board board (wah>fuzz>rangmaster), I'm gonna try swapping a Si fuzz (efe black acid) for a Ge fuzz (creepyface) and see how that works out.
    The Pork Loin is simply my favourite drive pedal ever. It's got a very natural type of break-up and decay. It's also got a nice amount of bass thump to it and you can tune in mids if you want them. It works particularly well with single coils, which are all I use.
    The OD-2 is a low-gainer with a slight mid hump, I find it works very nicely for slide. It's only drawback is a lack of volume, you couldn't use it as a boost. I've had an OD-2 since they first came out so it must be doing something right (for my style, anyway).
    @Sassafras you've got me thinking a pork loin could kick off the distortron! Does it do tweed-style low gain clean-with-a-bit-of-hair sounds or is it heavier than that?
    That's when it's at it's best. You can start off with an ultra clean boost and take it up to a lovely natural edge of breakup. It's got a clean blend but I don't much use that. On full gain, it never gets more driven than a TS-9 but it's got a lot more tonal variation than a Tubescreamer as well as retaining all the bass and all the clarity on chords.
    Pork Loin sounds pretty cool, I'll check one out one day.
    This thread has reminded me I wanted a DS1. So I bought a DS1. Damnit GAS.
