But you'd need to arrange that yourself as all of our organisational arranging capacity will go into making sure that the main room set list runs to schedule.
So, as first reserve, @TADodger, there's now a place available if you want it.
It takes seconds to edit a patch and 'Write it' so they can be tweaked quickly and easily on the day and even adjusted dynamically as someone is playing for those who know how and can hear something that needs it. It's easy, just leave Tone Studio open and make sure there are fresh batteries in the mouse.
I'll program as many patches with "useable" sounds and easy to recognise titles on a piece of paper so if people want to use it on the day, they're welcome to and they can quickly access patches that will approximate the sound of the record (Hopefully) or at least something generic that can be used for more than one song.
I'm sure lots will want to use their own effects but if some of the less experienced who are concentrating more on getting it played right than what effects they're using would like to use it, at least it'll sound something like it's supposed to.
Also if someone wants me to set them a patch up that will match their own amp at home etc, PM and I'll see what I can do.
It's not a helix but it's not rubbish either and you can always head to my place to hear it and set your patch up yourself.
I'll set everything up modelled with a view to running into either the PA or the 'Effects Return' section of whatever valve backline we have, assuming it has an effects loop.
2CM is fine as everything will be coming out of the GT but it does also mean there's a volume pedal and muted tuner built in too so it's an easy unit to use especially in 'Patch Mode', just go to the patch that either you arranged, wrote yourself or think describes what you're after.
To avoid life messing things up again, I'll be sending this piece of kit in advance along with @Bridgehouse so that if for some reason I can't make it, your patches and sounds do!
(That's assuming he's not picking me up ON HIS WAY PAST Bedford)
Is that ok ?
What was the payment situation, do I need to pay you or reimburse @TheBigDipper?
Don't worry about restricting your song choice to what TBD had picked. The setlist has only just been published and people are still deciding what they want to play. NB, we'll play popular songs more than once, so don't be put off if there's already a name in the slot for what you'd want to play.
If you need a drummer then let me know.
If you don't then please pop me on reserve.
I'm assuming that more than a couple of people will have to drop out before the day, so should see you then.
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
I'm mostly doing it to stay chilled out so I'm going to do a trip to Andertons on the 1st then stay in a Premier Inn and spend my evening practising with an amplug, so I can come in fresh and full of breakfast on 2nd ready to jam
As ever, thanks to the organisers.
Tim
@MtB - you're first on the reserve list, are you still interesting/available?
Enjoy Florence! It's beautifully hot & sunny over here in the UK atm.
Let me know what songs you'd like to play which parts on ...
£15 PPG to theFretBoard@outlook.com
