Hi Everyone,
I was taking some photos of my new R8, and noticed that the gap between the fretboard and pickup ring seemed a little wonky.
With my curiosity piqued, I thought I'd use the rulers in photoshop to have a closer look.
It appears to me that the body based elements are in alignment, but that the neck is in slightly wonky. There is also a slight chunk of the tenon that appears to have been skimmed off (I assume when it was fitted), on the side that would have to have more material off if the neck was to be fitted in such a way.
The guitar plays and sounds good and there doesn't appear to be an issue with string spacing (at least to me), but I obviously don't want to get involved with something that could be an issue down the line when I can easily swap it now.
Is this an issue to be worries about?
Many thanks in advance!
The 16th fret doesn’t line up with the body join either, which probably caused the gap.
but if it intonates, it’s all good
Instagram
(formerly customkits)
It sounds great and appears to play fine (I've only had it a couple of days and have had no issues so far). I set the intonation earlier today and all seemed good.
In the shop the G was playing up a bit but that seems have disappeared after it was restrung and set up.
I'm not bothered if it is not a bigger issue. If it is all good then I'll keep it and chalk it up to Gibson 'character'.
'We have replicated the idiosyncrasies of actual vintage guitars to bring you the most accurate reissue yet - all for just a two grand premium'. What a silly man
There is what appears to be a gap with a shim on one side of it on the bass side of the tenon. The joint relies on a good fit on the sides, since it rarely fits tightly on the bottom - the sides provide the bulk of the strength since the glue is in shear loading. If what I’m seeing is correct, there’s not only a shim, it still hasn’t produced a tight fit.
It’s not unknown for Gibsons to be shimmed on the sides like that - there are pics online somewhere of a LP Special where this was done... and the neck had fallen off.
At the very least I would want to take the neck pickup out and have a good look at that side of the neck joint.
its actually quite amazing how small a glue join you can get away with in a neck. I always try to maximise that join, but Gibson don’t feel the need.
i stick by my original assertion... it’s only an issue if it’s an issue.
weak neck joins are usually noticeable with tuning issues on every string and an odd resonance. Tap around the back and neck and you should get an idea if it’s a solid join or not
Instagram
Instagram
I'll get my macro lens out tomorrow and get a better picture. I'll also remove the pickup and get some images from in there too.
I've played around 15 of these R8's now, and I'd guess at least 5 had what looked like a little gap either on the left (as above) or the right. I was wondering what it was!
i was referring to the gap between fretboard end and pick up ring
Here is what we have at silly resolution. Please keep in mind that this gap is minuscule in real life.
Does this help focus your thoughts?
I mean, I agree with people that if it play great then there's no problem...
but that surely depends on how much it cost? For £300, no problem, you expect it.... For £2k? Should you expect better?
I just took order of a very nice Mayones... if there was something 1/10th as bad as this, for what I paid... it would be going back!
Ultimately, there's always going to be that niggling doubt in the back of your mind... is it cosmetic?.... or could it be a structural issue that causes a fail in a few years.
I'm certainly no expert, but appreciate your concern!
https://www.patreon.com/leviclay | https://www.youtube.com/c/leviclay
Instagram
Worth checking with something. If that gap goes deep, it will lead to a weaker join. If you can find them shim then it is structurally sound
Instagram
