Tonight I went to band practice, and played bass! OK I cheated slightly... thanks to @JezWynd, I am now the proud owner of a Satellite 24"-scale bass. One of those 1970s Woolworth's Specials . (Full write-up in the Bass section!)
Basically, because it's so short I barely have to move my arm - I have had to adapt some of my playing to more across-the-strings than my usual habit of sliding up to higher notes, and I still can't play a low F on the bottom string properly - I have to use my thumb - but considering it's only two days over a month since I broke it and just less than four weeks since the operation, I'm really very happy.
I purposely didn't tell the band I was planning to do it in case I had a last-minute change of mind after a trial run at home this afternoon, but in the event I shouldn't have worried - I was able to play almost all the usual parts, and my arm only started to get a bit tired after over an hour.
Guitar is likely to be a much longer process, chord shapes are still really hard - but for now, that will do.
My head said brake, but my heart cried never.
Nil Satis Nisi Optimum
I had a look at my X-rays as well, and to my surprise I haven't got a metal plate on the ulna - the operation description had said 'coronoid fixation' which from online photos I've seen is usually done with a small plate and a couple of screws, but mine was done with an internal suture, which you can just see as two faint dark lines running up from the bottom of the bone - there's a loop of cord through there and over the top of the broken bit apparently. The really dramatic bit is the 'radial head arthroplasty', which is what looks like a trumpet mouthpiece...
This was with the staples still in the skin from the last visit, it's a bit clearer than the one they took this morning, those have gone now and it's just a quite well-healed scar on the outside.
Not bad at all considering it's less than six weeks since the surgery.
Glad you are the mend.
It is boring, eh?
A lot of things do seem to take twice as long, and getting around by bus can be a bit tedious - well over an hour to do what would be a 15-20 min drive to one place I work - but actually I've been so impressed by how easy it is to get to Glasgow on the train that I might still do it occasionally anyway now, if there isn't a lot of big work to do. Not being able to carry my tools and amps is the only problem, but they have basic tools at the shop so I can do some jobs there.
I've also been able to catch up on a lot of old DVDs and downloads I've been meaning to for ages, although really that was only at the start when I was genuinely unable to move my arm much. Not having it in a cast was a huge advantage - almost as soon as it was operated on I was just down to a binding and a sling, and that went within two weeks and just left me with a bandage and the sling for outdoors to take the weight off it when walking - and I haven't needed that for over a week now.
I'm incredibly impressed by the skill and care of the doctors, as well as the technology available now - twenty or thirty years ago I think it would have been very different, and I'd probably still be in a cast. The only real problem I've got - apart from still being unable to do some arm and hand movements, and some pain - is drastic loss of strength in my left arm. It's worrying how quickly you lose the muscle if you're not using it. It will come back with time though.
I was back at the hospital today for a check - they think it's all going well, or at least as well as can be expected at this time after the operation, given the damage I did. I won't need any more work on it, but it will probably take a year or so to fully recover as much as it's going to - which may hopefully be complete in terms of movement.
I also asked to see the X-rays from the beginning and took a couple of pics, so I've added the one from the hospital before they fixed the dislocation and operated on it, back on page 2 in the right order. Be warned, it's quite scary...
At least I should have the option soon though - I can play the Rick sitting down now, just not quite standing up.
