does the high e look too close to the edge of neck
123457»
  • vizviz Frets: 10731
    Congrats!! That's an absolute bargain, and good to see such a nice guitar united with a guitar player and not languishing under someone's bed. Send her a pic of you holding a piece of paper with thank you written on it!
  • NeilNeil Frets: 3641
    Glad it all worked out for you in the end.
    With so many online scams going on it makes us all suspicious.
  • Dave_McDave_Mc Frets: 2371
    ICBM said:
    All's well that ends well!
    You were still right to be suspicious though - too many dodgy things about it and too many of the typical 'stories'… even if in this case they might actually heave been true!
    Agreed- they may well be true but you have to err on the side of caution, just in case. But glad it's worked out fine in the end :)
  • Paul_CPaul_C Frets: 7853
    if it bugs you, you might be able to slacken the neck screws slightly and pull the neck round enough to move the strings across a bit, then tighten them up again.
    I was going to do that but it's fine as it is
