The "SG" - why are they always crap??
  • riverciderrivercider Frets: 461
    Philly_Q said:
    I like SGs a lot, I find the body shape really comfortable and I've never found the neck-dive thing too much of a problem.
    But I have owned several which were not very good.  And I've given up trying to find a good one with a fat neck.
    I worry about the strength of the neck joint too, although the current design is sturdier than the vintage style.
    The PRS Mira (RIP) is a good alternative.  But again they should make one with a fat neck.
    The new Standard (i.e.not the 61) has a fat neck, long tenon and is pretty good.
  • Philly_QPhilly_Q Frets: 23130
    Thanks, I just looked at the specs - didn't realise it was a long tenon.  I suspect even the "rounded" profile might be a bit too skinny for me, but it's certainly an improvement on slim taper.
  • TTBZTTBZ Frets: 2912
    edited June 2019
    My 2008 Standard has a pretty fat neck, it's a 50s rounded apparently which is definitely a lot more substantial than a slim taper. Maybe look out for one around that year. I'd be tempted to sell or trade mine I think I just don't get on with the SG bridge pickup sound, I like more sustain/compression and "weight" behind the tone. The Bare Knuckle Warpig (well, Alegree's take on it) does help though.
  • Looks like SGs are only crap to those that don't get along with SGs.
    To me, PRS Silver Skys are always crap.
    I sometimes think, therefore I am intermittent
    Well it's just a glorified strat copy, so it was doomed from the beginning ;)
  • DrJazzTapDrJazzTap Frets: 2171
    I love mine......but i wanted type of guitar today, I'd buy a prs mira.
  • KeefyKeefy Frets: 2323
    But I tell you what - I'd love a nice double cut, but I don't see any around other than those Les Paul Special Double Cut's with the p90's.
    @IvisonGuitars ;
    That is all.
  • Matt_McGMatt_McG Frets: 328
    I liked the fairly recent SG that I tried, which had a fattish neck. Maybe a 2017 model? The only thing I didn't like was the finish on the back of the neck had that open grained feel, where you can feel the grain on the mahogany, and the neck was a little too D/U shaped for me. But in terms of tone, it sounded great, and sat nicely on the body.
  • stickyfiddlestickyfiddle Frets: 27248
    My 2000-ish Standard has a medium neck. Really comfy but not CS-Les Paul fat. The 2003 Faded Special I had before that had a huge neck, but bigger necks do increase potential for neck dive.
  • bluenilebluenile Frets: 48
    I like SGs but certainly can understand why they are a bit of an acquired taste - compared to normal guitars you have to swing them over to the right to sit comfortably and then there's the infamous neckdive which while not entirely cured, having a good suede strap has helped out immensely. YMMV just play what feels right for you ultimately
  • OilCityPickupsOilCityPickups Frets: 10722
    My last SG had no neck dive at all ... and once the junk 'circuit board' had been replaced with proper pots and caps it was a really fine guitar. I think they are guitars you have to try several of before committing to. I think the balance is so fine that a neck that's a fraction too heavy, or a body that's a bit too light can screw them up totally. I only got rid of the SG as I had too many humbucker equipped pickup demo guitars at the time and needed to thin out. If it had been a single or twin P90 instrument it would still be with me.
    I've got one of the first-generation Robot SGs which has not only the stupid self-tuners on the headstock but also some electronic crap built into the bridge and tailpiece, and a battery in the control cavity.
    It sounds like shit, both acoustically and plugged-in, and it's ludicrously neck-heavy.  On the other hand, it looks really great - metallic green with a bound headstock and ebony board.
    I keep wondering if new tuners, bridge and maybe an aluminium tailpiece would rescue it, or if it's just a lost cause.
  • RandallFlaggRandallFlagg Frets: 13960
    Are SGs crap as @cablesnightmarescatastrophes suggests?
    No, clearly not, see here for a superb sounding and looking SG:
    https://youtu.be/QwNM62TZ78I
    That version of Debussy is one of my all time benchmark guitar tones @RandallFlagg ;
  • robinbowesrobinbowes Frets: 3054
    drofluf said:
    Quite happy with my SG
    What's the other one? I'm tempted to get myself a mandolin at some stage...
    R.
  • Holy shit, I actually like that.
    Bye!
  • droflufdrofluf Frets: 3768
    @robinbowes Which one?
    On the right is an octave mandolin that I've now sold. The mandolin is a Hathway.
  • thomasw88thomasw88 Frets: 2335
    yamaha superflighter.
    look cooler, play great, are great,and for some reason are criminally cheap.
    no idea about lefties for them tho.
  • timmypixtimmypix Frets: 2426
    Rescue it! A guitar that pretty deserves a second chance.
    Tim
    This is the model (not my actual guitar).  I probably will try swapping all the hardware at some point, but I don't know if that will be enough to stop it sounding flat and dull.
    https://www.youtube.com/watch?v=JqYTNgwzwsk
