WezV Q1'20 challenge
  • WezVWezV Frets: 16676
    i was working with a very basic workshop  today until my move is done.
    it wast even the dining  room table, it was the end of a bed with a towel put over it.   If the frets needed  more levelling i would have moved to a solid surface, but since this was mostly polishing it was fine.   I feel like a teenager doing his first mods again, cant wait to have my workshop back.   although its nice to remind myself i can do a lot without fancy tools
    tool list:
    Sandpaper (400-1000g for frets, the 150 was for stripping the neck)
    Micromesh abrasive (1500-12000g)
    small firm but flexible sanding block
    sharpening stone
    Straight edge
    0000 liberon wire wool
    Tape
    Permanent marker
    fret guard
    fret rocker
    i  really struggle to take good pictures of frets, but they are nicely rounded and super shiny.  going to feel much better.   i also rounded the board edges at the same time, although it should be noted they were not as sharp as i expected at this price point
  • I'm a great fan of Squiers.
    They are a modders dream, because the basics are pretty much always good and give a great canvas for all sorts of modding sorcery!
    only thing i will note is the body wood choice wont hold a screw thread brilliantly.... which can be an unexpected pain for newbie modders,
  • SteveRobinsonSteveRobinson Frets: 7031
    Squier body wood can be a bit hit and miss. Here's the neck pocket of a recent VM Jazzmaster:
    That looks more like  i was expecting...
    i have since dyed the fretboard with darkbrown fiebings leather oil.  This then gets rubbed backwith the wire wool and i finish by oiling the board.   The dye does stain plastic, i have used it to my advantage here and let it tint the dots a bit.  i have purposely left them darker at the body end as that's how they tend to age.
    I also gave the neck a light tint, coat of oil and put it all back together.   the enck will get more work when i come to ageing the body, but its enough for now.
    Nut has also been reshapped and polished up a bit and with that all done i have given it a set-up.   Its now sporting a super low buzz free action... doesn't suit the vibe of the guitar, but im happy its capable of it.
    i also finally plugged it in, and the pickups are not terrible.  totally usable really.   the controls are also nice and smooth with a fairly even taper.... what is going on in the world!!
    I also dug out some spare parts
    before and after shots
    Nice work, Im always envious of what you do....they really are amazing little guitars for the money!
    edited February 2020
    Maybe I shouldn't have ordered a plate from China
  • TTonyTTony Frets: 27497
    If it’s sneezing when it arrives, walk away.
    Small news but the plate arrived from a UK seller... I figured the China one would be a while.
    Test fit with the white covers
  • WezV said:
    Nice.
    www.theflyingacesband.com
    I'm left with a choice.   The one with pickups is slightly better quality than the China plate, but not much in it.
    The china one is browner
    https://i.imgur.com/LhC5HZ8.jpg
    https://i.imgur.com/r5cFRUL.jpg
    https://i.imgur.com/KsYPLPK.jpg
    I should also say they will both end up a shade darker once aged
  • PhilKingPhilKing Frets: 1481
    I like the lighter one.  I seem to remember that the older plates were more like that.
    Finally found the slide switches I thought I had for this, but they were on/on, not the on/off/on I need to fit the plate.  Although I found another set of white  pickup covers I aged a few years back.
    I have ordered a toranado bridge and set of white button klusons.
  • Looking good @WezV - have long admired your work.
    He does make some exceedingly good guitars!
    Looking great!
