Axe_FX II Rigs, or: How I Learned to Stop Worrying and Love Digital Modelling.
  • ClarkyClarky Frets: 3261
    FW15.00 is out…
    backing up and installing right now..
    been looking forward to this one..
  • Si_Si_ Frets: 384
    Clarky said:
    @Si_ how's about you post the sysex of your preset and I'll take a quick look
    edit: if you can't post it, maybe email it to me
    Just got in from a long 2 days at work so will post it tomorrow.. thanks.
  • RolandRoland Frets: 8731
    Clarky said:
    Si_ said:
    No, just switching amp blocks on and off and switching between X and Y. what's the best way to do it?
    two amps, into a cab
    you don't need a mixer
    you assign the bypass of the amps to the same modifier
    bypass=mute
    when the IA switch is OFF, amp1 is active / amp2 is muted
    when the IA switch is ON, amp1 is muted / amp2 is active
    this method is seamless
    With this method the switching is instantaneous. You can come in and out of solo mode between beats. If you use a second IA to vary the amp settings, for example turning boost on and off, then you can have four amp sounds in one patch
  • Si_Si_ Frets: 384
    Is that instead of switching scenes, or as well as?
    I do all this with one IA [that sends two MIDI: CC commands]
    I actually use scenes to handle the bypassing of the amps
    this saves on modifiers that I can do other cooler stuff with
    I don't bother with scenes
  • Si_Si_ Frets: 384
    I find scenes easier to switch effects on and off. not sure how I would manage this without them..
    switching things on/off via scenes is far more flexible
    FW15.00 is in
    updated the amps with the new Utility
    fk… loving this one...
    Dizzy's okay now???
    yes... the VH4 and Herbert have got the shot in the arm they needed... last night I was goofing with the VH4ch3.. with the Diezels I like to keep the drive low and hit the boost, brit and sat switches.. can't describe why [and I know it's not a 'real' config].. but I just like it..
    the Herbert ch2+ is really nice too
    the 5153Red is a little different in a good way, which is unthinkable.. cos I love that amp..
    the DualRec [recto mdrn 1] is just fkn smokin'
    the new U-Res cabs are really nice too.. especially the TV [which I've always loved at nromal and hi-res].. this is a re-shoot and re-mix of that cab..
    So Sat switches are working fine now? Coz before they were sounding really wank in the beta - part of the reason I rolled back.
    they're mended now..
    when the Sat switches went all shite in 15b, a pile of guys complained [me included].. I suggested that if the Sat switches are there, either have them do nothing [to be true to the amp modelling], or do something cool [and there's nothing wrong with that right, even if it's in addition to the original amp].. but don't have it do something that sounds broke... a pile of us were all violently agreeing with this
    seem like he listened and mended it.. Sat does cool a thing now in the Diezels [as it did before 15b]
    Epic. I may upgrade later today then.
    I think you'll like the Recto Orng Mdrn 1..
    that's taken [imo] a major turn for the better
    Updating now. Gonna use my lunch break to fuck around with AFII - working from home today, yay!
    I'll be interested to see what you think...
    this weekend 'll be re-dialling in my reamping presets for the DC album.. I like this FW so much thatI'm going to re-reamp the parts I've recorded so far.. shouldn't take too long and it'll be well worth it
    Is it me or do the Fender models now sound like complete fucking shit??? Even after resetting the amp params...
    not tried the Fenders yet...
