what amp do you play through at home?
  • AllyAlly Frets: 64
    To nickb_boy,
    Lovely amp, I've been looking at these. I remember seeing you'd got one a while ago. What are your thoughts on it after having it a while?
  • EvildurkaEvildurka Frets: 351
    Now playing through, marshall sl5, evh 5153 50w and a vox vt15 :)
  • rossirossi Frets: 1707
    Mainly the Yamaha THR 10C or sometimes my Ibabnez TSA5.The 10c is perfect and I really only use the TSA5 for set up purposes as I use it at our regular jam sessions  in a studio where it keeps up with a drummer and bass .The TSA5 has an Emmi 105 legend  fitted  .
  • koneguitaristkoneguitarist Frets: 4168
    Either my Excelsior if it's plugged in or my lads old beat up Peavey Rage, does the job at low volume.
  • BlueingreenBlueingreen Frets: 2612
    Another Yamaha THR 10C  user here.  Definitely a step up from the Microcube it replaced especially for jazz cleans but the Microcube is a fine amp too.
  • dogloaddogload Frets: 1495
    This is my 'studio' rig, i.e. what I play through at home.
    It's a bit of a return to sense after a good few years of playing through my PC using Amplitube or Gig Rig. It's also going to be used for recording, using a DI/splitter to send a clean signal direct to the PC and another via my board to the amp to mic up.
    The Ashdown cab is there temporarily as it is my gigging cab (with my Selmer head).
  • FusionistaFusionista Frets: 184
    Tascam MPGT-1
    "Nobody needs more than 20 strats." Mike Landau
  • hubobuloushubobulous Frets: 2352
    Suhr Corso
    Marshall SL5
    Peavey Revalver
  • DeijavooDeijavoo Frets: 3298
    Those Suhr Corsos look pretty tasty.
  • ElxElx Frets: 412
    Guitar Rig 5 or Marshall JMP-1 and headphones :)
  • dogload said:
    What the heck is that thing far right that looks like a pink iced cake?
  • SimpleSimonSimpleSimon Frets: 1025
    edited June 2014
    Straight into a custom Blonde Minimat 2 head and cab, no effects......Curly lead is Mandatory...... Photobucket Pictures, Images and Photos
    @cosmiccarrot
    that would be a Hello Sailor fuzz, made out of a warship's emergency light, I do believe.
  • TeetonetalTeetonetal Frets: 7815
    Scuffham amps S-Gear a few pedals in the front end and a line 6 shortboard. And headphones :(
  • Mainly use a Ceriatone OTS Mini, or if the neighbors are out a Musicman 210RD. I have an Orange AD-5 as well which sadly doesn't get used that much.
  • strtdvstrtdv Frets: 2467
    @strtdv ...oh man...that Orange!  you sir are man of great taste!
  • ragingbenragingben Frets: 107
    I generally use the AMT Stonehead these days at home... I just find it easier to get satisfying tones at whisper volumes at night, which is generally when I get to play.
    It's tiny!
    I thought it would be a wee bit bigger than that.
