Got black ops on sale so I can blow off some steam. Might get back to slay the spire again.
If only my monitor wasn't 60hz.
FFS.
And it’s the worst time to get a new AV at the moment with the current line up having that HDMI 2.1 problem and so close to E3.
Currently playing Jotun which has a nice Norse mythology theme but the actual combat is a little clunky (compared to say Cuphead which is very much in a similar vein with the boss fights). Beautiful artwork though
Can't you plug into the TV and then output the audio to the receiver?
Ideally I would want everything to connect through the receiver, the receiver is due to be replaced anyway due to lack of 4k (my Amazon Fire Stick 4k is through that), and no Atmos.
Getting as high as 180 fps in places. I've got a 2060 GPU - I wonder what a 3090 could do with DLSS!
I'm using a mix of high and normal settings.
I got the new PC 99% for work, but it's very nice being able to play some games on it too.
https://youtu.be/4Zf1GCFoqn0
