Has anyone painted an enclosure with hammerite/rustoleum?
If so any tips? Did you use a primer? Did you paint or apply with a sponge etc?
Thinking about doing my fuzz face enclosure racing green. Or maybe late 60s dark grey.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
It works, but it was a bit messy and a bit of a faff to avoid paint runs or getting dust stuck in the paint. If you're patient you can do it.
My beloved Zuul clone randomly stopped working this week. It is sensing the key signal (as indicated by the two-tone LED) and it is passing signal through the gate section but it is not actually gating anything. I need a noise gate so I ordered a factory one. The clone was a real pain to put together physically inside the box but I will try to fix it
I need to test my new soldering iron. I think I have a rangemaster kit in the cupboard
FWIW I usually add the pots outside the box, resting the pots in the holes from the outside to keep everything still while I solder.
Will report back later.
Just finished a delay and reverb In one and add a momentary switch for repeats.
Will post soon.
Instagram is Rocknrollismyescape -
FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
How does it do the reverb @Cookiemonster is it a brick or FV1? I guess we'll see
edit: Jed's Peds do them
