Post-Lockdown pedal building
  • roberty said:
    @Cookiemonster I think Musikding do PCBs with pre-programmed SMD FV1s attached
    Yeah Jed's do as well. I do have one that didn't work I need to return to. It's been in a draw for ages, one of the few things that didn't work and the SMD element made my confidence levels in fixing it low. But think I will give it another try
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • stickyfiddlestickyfiddle Frets: 27482
    roberty said:
    How's the iron @stickyfiddle ?
    Still in its box... Possibly shouldn't admit that in here!!
  • Alex2678Alex2678 Frets: 1159
    Returned to the aesthetics of a pedal I built a while ago, it’s a fuzzdog ruckus (suhr riot) but I never liked how I’d finished it. My wife does sublimation printing and we got the supplier to make a 1590b sized aluminium plate. I think I’ll use these for future builds rather than powder coating or painting, they come in metallic red, gold silver or white for full colour printing. This one was a test and at least proved it’s doable -
  • robertyroberty Frets: 10912
    It happens! I bought an ultrasonic record cleaner in December and it has sat on the floor ever since. It will still be there when my attention comes back around
    @Alex2678 that looks great, what did you use to stick it on?
    I used a bit of double sided tape but I do think if I hadn’t the fixings for the pots and footswitch would’ve been enough, the tape helped while drilling though, I stuck it on and drilled out from the back through the holes in the enclosure. Very easy to drill though it’s very thin.
  • euaneuan Frets: 1582
    edited April 2022
    Does this count as pedal building if it isn’t actually in a pedal?
    PedalPCB prototyping board for experimentation purposes and finding out if I actually want to build a pedal. Has jumpers for Vref, 9V +/- and 18V so really easy to play with circuits they usually require a charge pump.
    Here is a 1981 DRV with a choice of clipping diodes. Quite like it with the harder edge of LEDs
  • Instagram is Rocknrollismyescape -
  • CookiemonsterCookiemonster Frets: 887
    edited April 2022
    So the above photos are three fuzz pedals I've made for a Forum Member.
    Two on tagboard and one on a pcb board.
    I had never used tag before, but the Paul had a project and needed a circuit, he got it from ebay and struggled with it, so I managed to fix that, and with the left over board built the tag.
    He also sent me two Sunface Boards, one for me and one for him.
    In the photos the White one is a Fuzzrite, Black one is a Tonebender and the blue one is the Sunface
    That looks great, I will need to have a look at one of these. Do you have a link ?
    https://www.pedalpcb.com/product/protoboard/
    Just comes as the board obviously
    @roberty I finally used the new iron yesterday for the initial wiring on my Jag build. Absolutely fantastic. Super easy to set and change temperatures, and it heats up and cools down extremely quickly, which is amazing. It wasn’t cheap but I’m a happy boy.
    The only real issue is I could do with a better stand for it as the handle is too narrow for my existing stand so you have to be very careful it doesn’t slip
    Sweet @stickyfiddle it makes such a difference doesn't it. My soldering became so much cleaner when I got a decent iron. I actually look forward to it now (a bit) (well, sometimes)
    Yeah, mine was never bad, but man I had no idea it could be easier!
    I really need a better stand though and google isn't helping. I might bump my old iron thread and see about recommendations from you lot
    My stand is the one with the hakko. It's great.
    Got a new oddly specific novelty mug today for my collection of oddly specific novelty mugs:
    @roberty PROPER chortle :D :D
    That I need
    That I need
    Not cheap but I had to have it anyway https://bandmemes666-3.creator-spring.com/listing/become-a-pedal-builder?product=1566
    Got a Ddymo today for quick and dirty labelling. Here's my wonky fuzz war, build three years ago with a hangover
  • roberty said:
    That I need
    I am still not the best a drilling. I need some drill templates
