Post-Lockdown pedal building
  • markblackmarkblack Frets: 1591
    found an old morse code key in a local antique place... so thought i'd shamelessly rip off copper sound pedals...
    raided the parts box... found an old enclosure... and here it is.
    it ain't pretty... well maybe it is in an ugly kind of way :)
    Any videos of that ?
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • poopotpoopot Frets: 9099
    poopot said:
    Following you on Instagram
    Cool!… ta…
    poopot said:
    Sounds good. And you can play with no hands!
    I have been called clever dick before now :)
    @Cookiemonster here you go, bit of a scrappy video but you get the idea,
    Now that's cool. So like a kill switch then ? Very inspiring
    @Cookiemonster yep.
    I'm sure you've seen them but these boys do it properly.
    https://coppersoundpedals.com/product/telegraphstutter/
  • robertyroberty Frets: 10896
    That's cool @markblack does it short the signal when engaged?
  • CirrusCirrus Frets: 8495
    It transmits it to a vintage radio enthusiast in Peru.
    Fantastic. That made me laugh
    "There's a guitar sound on my buzzing"
    it actually sends out a distress call to save people from my guitar playing.
    @roberty it's pretty basic just cuts the tip to tip signal when you press.
  • SporkySporky Frets: 28743
    Might be better to have it short tip to ground if you can.
    @Sporky did you mean like this?
    I did try it after you mentioned it - but it worked in reverse - the press brought the sound on... i'm sure it's me being thick.
    Yes - but it's quite possible that the switch is normally closed, and pressing it opens the connections, in which case your previous wiring is the only option - sorry.
    Does the switch only have two contacts?
    @Sporky i probably could get it to work but the way the old morse code key works all wiring would have to run to the front of the key - i'll have a play out of curiosity. cheers!
    Nuver one done
  • poopot said:
    Nuver one done
    I need to have a go at this. Need some wire
    Three done… all will be at the brum show.
