Neural DSP Quad Cortex
  • WazmeisterWazmeister Frets: 9659
    mrkb said:
    mrkb said:
    keir said:
    Patiently waiting for the @Wazmeister write up……
    …..In the classifieds? ;)
    Well I wasnt far off ;)
    You were actually miles away mate...
    If you read my thread, you will see I had doubts from the start.
    https://thefretboard.co.uk/discussion/233457/quad-cortex-tying-myself-up-in-knots#latest
    It's all about having the balls to try new things, and admit when it doesn't quite work for you.
    But I'm used to snipping from a distance... as you were ;)
  • allenallen Frets: 745
    I did a video comparing power supply noise for these.
    To be fair, only the real nerds will find this useful, but hey ho...
  • What cables is everyone using to go direct to FOH? I’m asking as a gigging guitarist who won’t be using my own PA, so I’ll likely be plugging into a DI on stage at the venue.
    If I’m using stereo delays and reverbs, how do I get this to FOH? Do I need to use a DI with left/right inputs? Or will a single TRS cable do the trick?
    Or, should I be coming out of L/R XLR’s?
  • John_PJohn_P Frets: 2753
    If you need stereo then you want two slt cables that can plug straight into the desk or stage box from the main outputs 1 &2.     A single trs cable would only give mono from one output.
    There shouldn’t be any need to use a di box but it would do harm if that makes it easier to connect.
    I run mine with outputs 1 & 2 to the Pa via xlr cables and output 3 to a backline power amp and cab for onstage sound.
    What’s an slt cable?
    The stages I play on are nowhere near the FOH desk usually. My singer usually uses a DI for her acoustic guitar so just presumed I’d do the same with the Cortex
  • mrkbmrkb Frets: 6986
    edited September 2022
    He means XLR or TRS (balanced jack) - depends on what the desk takes (usually XLR input) and what the Cortex has for outputs.
    Edit - looks like Cortex has either Stereo XLR outs (output 1and 2) or Stereo TRS outs (Output 3 and 4) - what outouts do you send the output signal to in the preset - can you choose?
    Karma......
    Ebay mark7777_1
    image.png 339.4K
    Sorry - auto correct,  that should have been xlr cables.       The QC has xlr sockets on the main outputs so there shouldn't be any need for a di box.
    Cool, so the stage should have somewhere for me to plug XLR’s into. I wasn’t sure if I’d need to have an XLR to jack to go into the DI. It’s not something I’ve ever had to do before, I’ve always just used an amp.
    I’ll likely still be running an amp/cab on stage as well, but that’s easy enough for me
    At the moment I’m running an instrument/jack cable into my SD170.
    I’d be setting the presets to “multiple out” when I’m gigging though
  • Is anyone aware of any good videos that go through how to understand the the routing/using the 4 paths and what effect that all has on the output sounds?
    I’ve tried setting up a couple of patches adding splitters etc and not getting the desired effect, but I think this may be down to not understanding what’s happening when I’m building the patches
  • rayttkrayttk Frets: 68
    I’m hanging on a few days for a 2.01 bug fix
  • onyironyir Frets: 46
    I updated yesterday and it's been working fine so far. Really enjoying some of the new included factory captures, in particular the Plasma Coil and the Tone King.
    The interface works a lot better, snappier
    New updated CorOS 2.1.0. Some nice new devices and QoL improvements.
    https://neuraldsp.com/quad-cortex-updates/coros-2-1-0-is-now-available
  • smudge_ladsmudge_lad Frets: 676
    Desktop editor beta launch is Oct 9th so hopefully not far away now
  • BGGBGG Frets: 695
    Im addicted to the new Victory and Matchless amps, they sound so bloody good.
    #thebatesmotelband
  • KultscharKultschar Frets: 46
    edited October 2023
    Many people using the QC still?
    You do feel they are *finally about to turn a corner so things could get interesting.
    I kept mine (also a Axe III user) but was close to selling just before the editor was unveiled as *real* as I do love the form factor, UI and for some amps prefer over the Fractal.
    I got sick of tweaking this thing on the floor with my bad back and used to Axe Edit for some long hours tweaking etc so do feel the Desktop editor will really boost the QC for me.     I own about 4 Neural Plugins so it's nice to hear Plini X is around the corner as it is one I own.
    Maybe its wishful thinking but I hope after the Editor is done and first plugin port is underway (One of the developers says on video Plini is in final stages) then bigger anymore frequent additions will occur - in particularly better and more FX.
    Hopefully things go up a notch from here.....
  • NerineNerine Frets: 2224
    Not sure why, but I still can’t help but feel the QC is still a bit half-baked.
    Will definitely be interesting to see the hype train build if the above comes to fruition.
  • nero1701nero1701 Frets: 1505
    I don't think they'll ever manage to fully integrate their plug in suite, I think that it's just false hope at this point.
