If you read my thread, you will see I had doubts from the start.
https://thefretboard.co.uk/discussion/233457/quad-cortex-tying-myself-up-in-knots#latest
It's all about having the balls to try new things, and admit when it doesn't quite work for you.
But I'm used to snipping from a distance... as you were
To be fair, only the real nerds will find this useful, but hey ho...
https://www.instagram.com/insta.guitarstuff/
If I’m using stereo delays and reverbs, how do I get this to FOH? Do I need to use a DI with left/right inputs? Or will a single TRS cable do the trick?
Or, should I be coming out of L/R XLR’s?
The stages I play on are nowhere near the FOH desk usually. My singer usually uses a DI for her acoustic guitar so just presumed I’d do the same with the Cortex
Edit - looks like Cortex has either Stereo XLR outs (output 1and 2) or Stereo TRS outs (Output 3 and 4) - what outouts do you send the output signal to in the preset - can you choose?
Ebay mark7777_1
I’ll likely still be running an amp/cab on stage as well, but that’s easy enough for me
I’d be setting the presets to “multiple out” when I’m gigging though
https://neuraldsp.com/news/coros-2-0-0-is-now-available
Collision rock band
The interface works a lot better, snappier
Collision rock band
https://youtu.be/7dVV3moAuLk
https://neuraldsp.com/quad-cortex-updates/coros-2-1-0-is-now-available
Collision rock band
You do feel they are *finally about to turn a corner so things could get interesting.
I kept mine (also a Axe III user) but was close to selling just before the editor was unveiled as *real* as I do love the form factor, UI and for some amps prefer over the Fractal.
I got sick of tweaking this thing on the floor with my bad back and used to Axe Edit for some long hours tweaking etc so do feel the Desktop editor will really boost the QC for me. I own about 4 Neural Plugins so it's nice to hear Plini X is around the corner as it is one I own.
Maybe its wishful thinking but I hope after the Editor is done and first plugin port is underway (One of the developers says on video Plini is in final stages) then bigger anymore frequent additions will occur - in particularly better and more FX.
Hopefully things go up a notch from here.....
