Post-Lockdown pedal building
  • robertyroberty Frets: 10913
    Is it me or does this switch look like it's not soldered in properly? I cement the entire hole with solder when I do mine
    https://www.ebay.co.uk/itm/265832562220
    That's what I do too, but not through any sort of expertise. I figure the stronger the bond between the switch and the PCB the less chance there is that it won't make contact. Easy enough to do yourself later I guess...
    I'm genuinely curious. Maybe I'm overdoing it, but filling it in completely would seem more solid to me
    Looks like we're double posting each other today :-)
  • @roberty @english_bob thanks for that - I have a go at that and see if there's any joy. I know it's going to be 100% my lack of ability but you live and learn :)
    It does look like the transistors are in backwards unfortunately
    https://www.jedspeds.co.uk/product-page/axis-fuzz-roger-mayer
    They are sensitive to heat, and having 3 legs are tricky to desolder and remove. If you can get them out with the legs intact you still run the risk of frying them in the process
    If it's any consolation I fried a couple of semi-precious Russian germanium transistors a couple of years ago. I have a mini-graveyard of borked PCBs beyond resuscitation
    Sorry @markblack that was a bit fatalistic
    I would snip the transistor off its legs and desolder the legs from the PCB one by one. Anything more than that and you risk damaging the tracks on the PCB
    The transistors are common modern ones, you need a 3906 and a 3904, about 20p each:
    https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=140_151_153&products_id=1069
    https://www.bitsbox.co.uk/index.php?main_page=product_info&cPath=140_151_152&products_id=1068
    Bitsbox are good for small orders because the lowest shipping tier is £1.90
  • euaneuan Frets: 1593
    Always try and socket your transistors. For this very reason.
    Side note something that just popped into my head that isn’t related, don’t get your TL071s mixed up with your 72s otherwise you’ll end up troubleshooting something that isn’t broken
  • english_bobenglish_bob Frets: 5204
    edited September 2022
    Good spot @roberty - that'll definitely stop it working the way it's supposed to.
    @markblack - it's tricky to get transistors out of a PCB without damaging them but it's not impossible.
    It looks like the transistors are one 2N3904 and one 2N3906- if you need to replace them I've generally found that it's most economical to buy from eBay- you'll probably need to buy more than one of each, but it'll cost less than placing a tiny order with any of the big electronics suppliers (who are geared to fulfilling big orders) because you'll pay much less in postage.
    https://www.bitsbox.co.uk/ are good for small orders too.
    Worst case scenario, you can just order the whole lot again from Jeds Peds, just go for the "PCB and components" option and re-use the box.
    @roberty - double posted again!
    Sometimes the sockets are more valuable than the transistors. For unobtanium transistors I solder them in directly but leave a lot of leg so they can be repurposed. I'm not really a fan of sockets but that's probably just my bias (no pun intended), I've had a couple go bad on me. I do socket ICs though
  • If you use a solder sucker the engineer one is good. It's not to bad removing parts. I have very few times now where I burn a pad.
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • For transistors and parts I use bitsbox. They are sent very quickly
    The absolute number one tip for building pedals has to be to go slow, keep everything ordered while you're building and double check everything before you solder anything. Pretty much every mistake I've ever made building pedal kits has been because I was rushing and not paying enough attention. Sometimes they're easy to rectify, sometimes not, so it's better not to fuck up in the first place.
    That said, I'm not a fan of Jed's Peds' instructions- they have a habit of hiding important details (component orientation, trimpot settings etc) in amongst stuff you don't necessarily want to read, like explanations of how components work, so it's easy to miss something that might turn out to be important. (credit where it's due- some DIY suppliers' build guides are woefully lacking in essential details, and Jed's are emphatically not in that category).
    Build Your Own Clone are the best at guiding an absolute beginner through the process of assembling a pedal from a kit, and a lot of what's helpful in their step-by-step guides is applicable to any pedal kit you buy, regardless of where you get it from. It's the height of nerdiness, but I'd say that reading one or two of their instruction sheets might be a good introduction to pedal building even if you never buy one of their kits.
    https://buildyourownclone.com/
  • @roberty i flipped the transistors - had to snip them i the end and hey presto it's fuzzy! the soldering ain't pretty but I'll put that down to a lesson.
    Thanks to everyone else who chipped in - super helpful as always.
    Cheers
    Mark
    @markblack great stuff Mark. Not easy to flip a transitor! It's a great circuit, enjoy
    Hakko sponges on Amazon! My one's knackered
    Hakko Soldering Iron Cleaning Sponge A1559 , Grey https://amzn.eu/d/6t78Xfw
    I think I'm going to order a Belton Brick reverb from Fuzz Dog, the one with the tone control. I'm hitting a dirty amp and I think it'll work well in that context. I have a True Spring which is literally perfect as a spring emulation, but it's maybe a little too complex for my needs
    Did a few light bits and bobs today after a fairly heavy night
    i was right about the Belton Brick, it does sound good into a crunchy amp. I got the long spring tank, think I would opt for medium if I could choose again. It's lo fi and trashy, reminds me of BBC Radiophonic Workshop. A friend is drawing some graphics for the decal
    The MZF-1 is interesting. It sounds a bit lacking on its own but pushing a dirty Marshall style amp it is glorious. I think it'll work well on bass so I look forward to giving that a try. I've got some graphics ready for the decal
    Very inspiring.
    I made a moonn electronics one that is very strange. And just finished a delay for someone on a band locally
  • KeefyKeefy Frets: 2341
    The Belton Brick module is based around three PT2399 digital delay chips. Quite a few 'spring delay' pedals use the same approach, from the budget (Mosky Spring Reverb) to the boutiquey (J Rockett Boing). I have the former and it works surprisingly well, with the advantage that the dry signal remains analog.
    Got any pictures @Cookiemonster or links?
    @Keefy I really like the brick delay. Trashy and lo-fi. Thinking about it real spring reverb is considered trashy and lo-fi in the production world. Rudy van Gelder's treatment of Miles Davis' trumpet is probably the most well known example outside of guitar
    I put the Fulltone Mas Malo PCB together this afternoon. It has a squelchiness in the treble that reminds me of the Boss FZ-1w. The EQ stage is very well considered. I'll probably give it a go with my band
    I think I'm getting the fuzz bug back again. Maybe I'll get a breadboard and conduct my own fuzzy experiments
    The Eye of Horus was used as a sign of prosperity and protection. I used an ink stamp for this design. I was trying to get it broken up like an old EHX pedal, not sure I succeeded. But it is a great pedal and a clone of the Barbershop from Fairfield Circuitry. I altered it a little and gave it more gain. The Sag Control does wonders to the tone. It's probably my favorite drive pedal. The Jfets are 201 SMD and it really is touch sensitive.
