Currently I'm using several cheap and cheerful bronze coloured Adagio lever capos that I bought off Amazon for about 7 quid a few years ago. Simple, accurate and quick to use, you can pop it on the headstock if that's your preference.
https://www.amazon.co.uk/Adagio-Suitable-Acoustic-Electric-Guitars/dp/B071DTMHVP/ref=asc_df_B071DTMHVP/?tag=googshopuk-21&linkCode=df0&hvadid=310786528304&hvpos=&hvnetw=g&hvrand=12507270916540019264&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9046002&hvtargid=pla-549618684871&psc=1
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
https://www.ebay.co.uk/itm/275748727411?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=020KK9rwT0a&sssrc=2349624&ssuid=yGZIWTVDQ_-&var=&widget_ver=artemis&media=COPY
You probably won't find another and at this stupid price you won't want to either!
They go on with the hand grip above the neck.
I still now and again, go to grab the "rear" trigger when using the Nashville, but soon get used to it, and you really dont need to use the picking hand at all
First impressions:, light, well made and doesn't take as much force to open it up as my Kyser.
Not used it yet. Interested to see if it knocks the guitar out of tune.
EDIT: and it doesn't. Pleased with it. Good steer! Thanks @bertie.
I can't see the point trying anything else right now.
https://youtu.be/UWGj-KIfswI
The Ferguson is interesting. It has a radiused metal tongue that slides between the strings and the fingerboard. I'm not sure what the benefits of this are. It makes the capo quite fiddly to fit, and also sits higher than the fret, so raises the action slightly. I assume it must be there for a reason, but I have no idea what it is! In my brief experiments so far I haven't noticed anything that would justify the claim of 'perfect pitch'.
Anyone ever come across this device before?
I've also got one of the cheap and cheerful ones with a strap that hooks on the top and a plastic "lever" to tighten it. It's not the easiest to fit initially but you can easily loosen it and slide it up or down without removing it.
Both work fine with different guitars because they have rubber block contacting the strings that moulds to the shape of the fretboard.
I don't have a guitar with a flat radius though.
Anyone tried a "rolling" capo?
https://edmorgan.info
From my research, on paper the most cost effective ‘flexible’ option seems to be the G7th Performance 3 ART, which seems to fit all widths and radiuses. Does anyone have any hands-on experience with this particular model to give pros and cons?
The very different. Design of the G7th Heritage and Paige 6 string ETI PC-6-ETI are interesting and seem to get praise from many. However they’re 2-3 times the cost, won’t deal with all fretboard widths and look like they require two hands to make changes in use where the Performance doesn’t. Is there a compelling reason why this design works better than the ‘Performance’ style of capo to justify the outlay? I have read the comments above carefully, so hope I’m not duplicating.
