WezV - building an electric with the laser cutter.
  • WezVWezV Frets: 16793
    Remade the headplate shorter, and a much better engraving this time.  Though I should include a grain matched truss rod cover too.
    0reaction image LOL 5reaction image Wow! 1reaction image Wisdom
  • StrangefanStrangefan Frets: 5844
    Do you have the air pump attachment? That would prevent any of the scorching you're getting near the logo,
    Yeah, air assist was running.   Although I keep seeing conflicting info on whether it should be used for engraving, or just cutting.
    I'm quite happy with the new one, should clean up fine.
    The new one does look great,
  • That looks excellent.  What's the difference in settings between that and the old, slightly fuzzy, one? Presumably to do with laser power and head speed.
    the first one was done at too low power/high speed.  I tried to do another pass but lost alignment slightly so it lost definition.  I think i also used the offset fill setting for speed.
    The newer one was done on the slower fill setting,  at a slower speed.
    there are 3 main modes on the laser
    Line - it draws the outline of the shape
    Fill - it fills it by moving side to side like a printer head.
    Offset fill - Draws the outline, then moves inwards drawing the same shape
    fill vs offset fill is not that different on a solid shape
    but for hollow shapes  it makes a big difference
     red shows the laser head movement, lots of wasted moves with fill
    Offset fill is a lot quicker, but fill is more consistent.
    Offset fill can also do odd things with unusual shapes
  • @WezV interesting, thanks :)
    i had a slight mishap with the top.
    After doing the headplate I decided to try and re-do the body engraving.  I got it all aligned nicely by pre-engraving the shape onto a backing board and running the program again.  It was running well, so I stepped away to water some plants for a minute.  Big mistake
    I missed a slight curvature of the top, which meant that the laser guard pushed the whole thing out of alignment, and started engraving in totally the long spot.  It is set up with very little clearance so you get the best eye protection from the shield.
    the lesson here is to hold thinner bits of wood more firmly before engraving.  I should have stuck it to the backing board with double side tape
    I've left it alone for a couple of days trying to decide the best way to fix it.  The obvious answer is to cut a new top along with pickups and plates to match.
    But i wasn;t quite ready to give up on this one.   The slight bowing that caused the issue  makes it difficult to plane or thickness out as is, so i've decided to glue it into the body first.  Hopefully I can route 1-1.5mm off the top of the whole thing, and re-engrave after.
  • SeshSesh Frets: 1853
    Oh no, what a shame. This thread has been fascinating so far. I'm sure you will be able to sort it though.
    Can't sing, can't dance, can handle a guitar a little.
    There are always issues to overcome when trying new things, so I'm not too phased by it.  I know at this point it's better to think about a solution for a few days before I attempt anything rash.
    The alternative would be to walk well trodden paths, or even not bother building the bloody things at all.
    1reaction image LOL 0reaction image Wow! 3reaction image Wisdom
  • sev112sev112 Frets: 2799
    Turn it over for a lefty
    edited June 2023
    nah, i hate making lefties as i can't play them
    also, its currently in clamps
    I took 1mm off the whole top, just need to re radius and sand out the whole thing before i move onto the neck pocket
    0reaction image LOL 2reaction image Wow! 2reaction image Wisdom
    Neck route jig
    Top re-engraved.  Just one border this time.   The plan is to leave the outer edge and pickups natural, maybe put a nice colour in the middle.
    I did actually use offset fill again here as it takes 20mins instead of 2 hours .... but I changed the spacing between the laser path for a bit more overlap, giving a much cleaner cut.
    I also slimmed down the outer border.... which I think looks loads better, but now doesn't match the headplate.  I'm okay with that as the visual difference will be reduced when the middle bits are sprayed a different colour.
  • PeteCPeteC Frets: 409
    Great job.  Love the pinstripe effect round the body.  I think a second version with the body roundover replaced by a bold chamfer where the maple top starts would look amazing too.
    That could work.   For this one I am sticking more with a vintage Zemaitis feel for most if it, just with some updated aesthetics
    I'm really struggling to decide on a colour that would work well, so may have to do some photoshop mockups later
    Look forward to seeing those.    Ive been wanting to add a thin abalone pinstripe to the centreline on a couple of my builds but havent tried yet - a laser cutter would be perfect for cutting those - but rather overkill !!   What inlays will you be using?
  • JalapenoJalapeno Frets: 6399
    Awesome work, you are the new Tony Zemaitis !
    Feedback
  • Jez6345789Jez6345789 Frets: 1801
    Keeping with the Zemaitis feel what about steel grey wood on the insert possibly classic cherry on the outer?
    There are some tutorials getting a nice grey blue steel look on flamed woods.
    Sure you will come up with a winner.
