There's so many available amps on ToneHunt, I didn't know where to start.
Stumbled across a channel on YouTube demoing a few of the higher gain amps, which may appeal to some;
You can also use the NAM fx with other software, one of my favourites being the NAM drive/fuzz pedals into Helix Native.
Further info here: https://www.neuralampmodeler.com/post/the-first-publicly-available-parametric-neural-amp-model
https://github.com/sdatkinson/NeuralAmpModelerPlugin/releases/tag/v0.7.9
soundcloud.com/thecolourbox-1
I sort the captures into directories, e.g. Clean, Breakup, Rock, Metal, etc., and then I unzip each category into it's own folder. This makes it easier to navigate through a collection of similar amps. After that I reamp a riff to find the best sounding amps using the forward/backward selector on the NAM plugin.
It's a bit convoluted but I can't think of a simpler way, and there's not much else you can do as that is the only functionality available at the moment.
https://tonehunt.org/emil.rohbe
But was discouraged to read on the FB forum that capture submissions to Tone Hunt have slowed down quite a bit in recent months and the whole NAM hype has died down.
