Then, after that, we can focus on which ones attract vocalists. It's usually easy to find guitar players (ten a penny
I expect we'll have to accept that some of these will have to go and we may have revert to some from previous jams.
If I were to rank, I would go in order of -
Sweet Jane
Hanging Around
The Passenger
Queen Bitch
Public Image
@spark240, I've got you down as Lead Guitar for all the Clash songs, so shout if that's too much. Although, I expect some might get dropped if we can't fill the other roles.
**Image removed. See more recent post for the latest update of the song list**
https://twitter.com/spark240
Reddit r/newmusicreview
Just to move things fowards a bit. @mrkb , in the current list, can I assume you're OK for the ones you played drums on at the last jam which are:
La Grange (ZZ Top)
Have just made a playlist of the new proposals - and there's currently 17 songs - over an hours worth to go through and see if they are playable and check if a drum tab is readily available - so will do a few a night over the next few nights. But Im only going to learn 6 new songs max (they take 2-3 hours each to get scored out correctly - more if I need to learnt specific "non 4/4 kick snare" bits)
New suggestions playlist
https://open.spotify.com/playlist/5ygoSIN4YYFmoOBbE919AI?si=7bc3f1679c73415f
Initial thoughts-
Sweet Janes - ok - simple enough to learn.
Move over - Slade. has a tricky hihat pattern at 2-3 mins that will take alot of effort to get upto speed.
Passenger - ok - simple enough to learn.
London Calling - some tricky hit hat triplet patterns - doable, but alot of work.
Ebay mark7777_1
I can go shopping for Bass / drum / vocalists if required ?
Ebay mark7777_1
We've now got enough roles to get through 'Champagne Supernova' (assuming @Neilybob is happy to play it without a 2nd guitar , and also enough to get through Rebel Yell.
Do you think it would be good to have a quick roll call to see who is confirmed so far ?
Also may be worth putting the songs from previous jams back on the list to pad out the set list. Appreciate its extra work @stratman3142 but the completed line ups are a bit thin on the ground at the minute
@mrkb ;@Brocco @roberty @stratman3142 ;@Bennyboy-UK ;@Jonathangus @bobblehat @Neilybob ;@Vibetronic
@SPECTRUM001 @designerseye88 @bertie ;@spark240 ;
